  #1
Old October 14th, 2008, 02:02 PM
cool1 cool1 is offline
Default Yamaha 1999 F50 Trouble Shoot Electrical After Hooking Battery Up Backward
Hello All,
We are having issue's with 50H.P. F50TLRX, My Bro-In-Law, Hooked battery up backwards and pop'd fuse in the engine comp, Now we have No spark. We did get the repair manual, But NEED Help. Whats the best easiest way to trouble shoot and fix this?? many Thanks All. Bob.
  #2
Old October 15th, 2008, 09:14 AM
Yamajoe's Avatar
Yamajoe Yamajoe is offline
Default Re: Yamaha 1999 F50 Trouble Shoot Electrical After Hooking Battery Up Backward
this motor may have 2 fuses
  #3
Old October 15th, 2008, 11:10 AM
Where would it be, We have the manual and its not jumping out at us???
We shorted the battery on a 40 hour used Yam 50TLRX, Whats the best way to trouble shoot and fix this correctly. Thanks Bob.
The starter is cranking fine, we see fuel behind the glass of the fuel filter and there is no spark to the spark plugs...what should we test next?"
  #4
Old October 15th, 2008, 12:03 PM
douglloyd douglloyd is offline
Do you have the kill switch tether installed?
  #5
Old October 17th, 2008, 09:55 PM
Yamajoe's Avatar
If the starter is cranking then your fuse is ok. you can find the fuse by tracing the positive (black) lead from battery to the starter relay, the blck lead from batt. sits on red lead on relay post next to a brwn lead ( brwn lead goes to nuetral switch) , trace the red lead from relay and you will locate the fuse.
As you don't have spark, what is the condition of the plugs, get a good plug and check for spark on all coils; check the white lead from CDI to the tether for shorts, this is a cutoff switch, is does get frayed or burnt and this will short, and will not give you spark. You have a neutral switch, the brown lead from the starter relay goes to the neutral switch, move the gear handle back and forth and back to neutral as check for spark.
a simple OHM tester will be useful to test for continuity etc.
  #6
Old October 18th, 2008, 11:09 AM
rodbolt rodbolt is offline
if the starter cranks the engine quit chasing brown wires as the cranking circuits are working.
no sense in testing a working circuit.
this set up uses a basic CDI ignition.
without the harness diagram in front of me first isolate the white kill circuit wire. if its grounded or the keyswitch is damaged it will shut down the computer.
hooking the battery up backwards may blow the fuse for the rectifier but I cant think of why basic spark would be affected.
start by testing the pulser coil inputs to the CDI then test the output of the CDI with a peak reading meter or a DVM with a DVA adapter.
do a forum search for a home made spark tester.
if I make it to the shop today Ill try to look it up and check for 12V inputs to the CDI/computer.
I dont see a lot of the F50 motors so I dont memorize much but it does use a basic ADI/CDI system.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
F50 tlrx 1999 Yamaha rattle in lower gotboostedvr6 Yamaha & Suzuki Outboards 14 May 17th, 2008 03:01 PM
Trouble shoot a fuel gauge FishnMike Electrics, Electronics and Trolling Motors 2 May 15th, 2008 07:28 PM
1999 Yamaha F50 Power problems Len Dog Yamaha & Suzuki Outboards 1 August 7th, 2007 02:42 AM
650 merc battery hooked up backward cleek Mercury & Mariner Outboards 11 June 22nd, 2002 07:48 PM
JOHNSON 85hp 1976, Battery hooked up backward. What Smoked? Don Smith Johnson & Evinrude Outboards 5 May 27th, 2002 03:29 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
