  #1
Old October 14th, 2008, 03:58 AM
deejaycee_2000's Avatar
deejaycee_2000 deejaycee_2000 is offline
Default 5hp mariner idle problem
Hey guys, I am having an issue with my 5hp mariner 2-stroke, it is a early 80's model and is basically still as good as new as it has not been used alot over the years but always well maintained, but this motor has always had this bad temper. I gave the motor a good service, cleaned the carb, the carb setting is perfect, but it does not wanto idle, if I keep the revs high it will stay running but it will not idle, it will starve for fuel the moment the revs drop, I have adjusted the carb but it does not change, still no idling, anyone have any ideas what to try next?
__________________
__________________________
... THE MAXIMUM HORSEPOWER IS NEVER ENOUGH ...
  #2
Old October 14th, 2008, 12:21 PM
Wee Hooker Wee Hooker is offline
Default Re: 5hp mariner idle problem
So you pulled and cleaned the carb? Low speed jet (and throttle valve) is reset to initial settings from manual? Sure choke is disengaging? Sounds like your not getting enough fuel ( or too much air)
One of the tricks I use to verify it's fuel starvation is to put some 50;1 mix in a old ( cleaned) Windex bottle and spray it down the throat of the carb as it wants to stall. If revs pick up, it's either starving for fuel ( or you have a air leak.) in either case, sounds like the carb needs to come off again.
  #3
Old October 15th, 2008, 05:27 AM
I took the carb off a 100 time allready hahaha, how do i adjust the throttle valve?
__________________
  #4
Old October 16th, 2008, 05:01 AM
anyone?
__________________
  #5
Old October 20th, 2008, 04:41 AM
bump
__________________
  #6
Old October 23rd, 2008, 03:49 AM
no-one?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Nissan 1992 5hp - Idle Problem Terry Adair Honda & Tohatsu/Nissan Outboards 2 July 9th, 2008 09:57 PM
Honda 7,5hp (older) problem with idle power/speed IvanJ Honda & Tohatsu/Nissan Outboards 3 June 23rd, 2008 05:54 AM
Mariner 5HP fuel problem... demo316 Mercury & Mariner Outboards 0 September 11th, 2007 01:56 PM
Problem with mariner 5HP Outboard demo316 Mercury & Mariner Outboards 4 June 12th, 2007 06:32 PM
Mariner 3.5hp choke problem SeaBear Mercury & Mariner Outboards 8 May 30th, 2001 02:23 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
