  #1
Old October 13th, 2008, 08:36 PM
timsmcm timsmcm is offline
Default Replacing thermostat on 85 15hp evinrude pulling powerhead
what parts do I need to get to get the job done right gaskets, bushings etc? I have an 81 service manual and that was the closest year manual I could find.
  #2
Old October 13th, 2008, 08:44 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: Replacing thermostat on 85 15hp evinrude pulling powerhead
diagrams and parts list can be found here: http://shop2.evinrude.com/ext/index....cfd8a6471c0f7f
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old October 14th, 2008, 08:32 AM
BaitThrower BaitThrower is offline
You do not need to pull the powerhead from the shaft (if that is what you mean?). However, you will need to remove the cylinder block cover and take the outer water jacket with it. You cant remove the water jacket alone because the cover latch gets in the way.
So remove the cylinder head cover, then the water jacket cover to access the thermostat. Ideally you should replace the cylinder head gasket and water jacket cover gasket with new ones, plus put in the new thermostat with new thermostat gasket/washer.
It's a bit tricky getting to some of the bolts on the cylinder head, and especially tightening them up again on re-assembly, but it can be done and saves you having to pull the whole engine block off the shaft.
  #4
Old October 14th, 2008, 11:08 AM
bait thrower what did you use to get the head bolts out looks like a little room to get to it and also how did you torque the head bolts.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Changing Thermostat on 85 15hp timsmcm Johnson & Evinrude Outboards 10 December 10th, 2008 10:30 AM
Replace thermostat without pulling powerhead? 16sail Johnson & Evinrude Outboards 11 July 16th, 2006 07:40 PM
'85 30 hp Evinrude thermostat Q? rfcoop Johnson & Evinrude Outboards 2 July 7th, 2005 05:53 PM
Replacing thermostat 87 50 hp Evinrude llfish Johnson & Evinrude Outboards 4 June 23rd, 2005 09:48 AM
69 Evinrude 115 to 85 powerhead swap? scorpionryder Johnson & Evinrude Outboards 4 March 23rd, 2005 02:26 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
