Re: A Heads Up, Starting Issues, Attention All!
Hmmm, never had to warm up the ignition.
Open fuel tank vent
Check the kill switch, place in "run" position
Squeeze fuel primer bulb till firm.
******* Advance the throttle 3/4 way, without putting it in gear. -- This is done by either pushing a button in the center of the controls, or pulling the shift handle toward the driver, or raising the fast idle lever, all depending on what controls unit you have.
Activate the choke (fuel enrichment valve) by pushing in on the key. The valve is only open while the key is being pushed in.
Turn the key to start while continuing to hold the key in.
Release the key and choke when it starts.
3-5 seconds of "choke", is usually enough.
Be ready to pull the throttle back toward the idle/neutral position, when the engine starts and the revs increase.
Continue to pull the throttle back as the engine warms up.
You should not have to use the choke much, if at all, once the engine has warmed up.
Engine should start within 10 seconds of turning the key.
As I said, starting using "normal procedure"!
I never had a problem before either!
But not this time during de-winterization about a month ago!
I had my son helping, the boat ready, hitched up to the car, went to start it using the usual procedure, no go, finally killed the battery, not even a sneeze? pulled out the plugs, cleaned them with carb cleaner, cranked, & cranked, no go, let the battery charge awhile, put some starting spray inside the cylinders, No Go! Got in the boat, hit the carbs with some starting spray, No Go, agan not even a sneeze??? Finally after a little while, and more starting fluid, it began trying,,, then finally it ran! But, I saw a stream of water shooting out of the side, rear, of the motor
Well guess what? the exhaust cover gasket blew out in one tiny spot!
So, I shut it down, unhitched the boat hitched up the jetski, and went to the lake.
Cut to yesterday, after removing, 27 bolts, 1 broken, 2 gaskets- $27, one bolt drilling out, & retapping, and a ton of gasket scraping, & cleaning, it was back together finally, I took out the plugs, and cleaned them again, put the battery charger on it first, and now to start it up, and test it,,, Same Scenario as before, a No Go!
While my neighbor went to get his starting fluid, I decided to leave the ignition on till he got back, a coupla minutes, I couldn't get into the carbs with the cover on them having no spout on the starting spray can, so I just sprayed the inside of the cover a bit, hoping it would bounce off, and get into the carbs, I hit the key, and the motor just took off, & started! no choke, no nothing? I went to idle it down, it stalled, but then started on it's own, & kept running, better all the time as it warmed up,,,, just like nothing happened in between?!
So, the best I can figure is, by leaving the ignition on for a few minutes, it started right up, & kept running, it was not really anything to do with the tiny amount of starting spray that never got directly into the carbs.
