I have a '01 20' Triton with a 2.5L 200 EFI, 25P Merc 3 blade prop. The engine in newly rebuilt, due to a ring hanging and breaking #5 piston. The boat has never had a good hole shot. The engine sometimes runs like a bandit, decent hole shot, then later in the day or after the engine gets warm, bad hole shot. The engine labors up to about 2900-3300 rpm then seems to hit the "power band". Once this rpm is reached, runs good. Can turn the Merc Prop at 5700-5800 rpm in hot weather. Engine makes great hp on dyno.
I've been told to put a Power Tech 25P 4 Blade Prop on it, which should cure the problem. Also told, the Merc 3 blades aren't the best on heavy 20' Bass Boats.
Is my problem an engine issue, fuel, or prop? Any suggestions would be greatly appreciated.
