  #1
Old October 11th, 2008, 07:35 PM
barryb barryb is offline
Default 1998 6hp mariner lower unit removal?
Just bought a nice 6 hp (1998) Mariner and saw some oil leaking from the unit,
So I have worked on some outboards and surely can't be hard? how do you get the darn *****shift lever out of the head? Any help would be great Thanks.
  #2
Old October 12th, 2008, 11:11 AM
TOHATSU GURU's Avatar
TOHATSU GURU TOHATSU GURU is offline
Default Re: 1998 6hp mariner lower unit removal?
You pull the powerhead...Why would you remove the shift lever to get the lower unit off? They have nothing to do with each other.
__________________
Elvin
My answers are like Zen...It may not be the answer you want, but it is generally the answer you need.
My Three Rules:
1) Look in your service manual first.
2) Have basic mechanical skill.
3) If you are confused, take your engine into a dealer.
  #3
Old October 12th, 2008, 11:33 AM
I have the motor on a stand, removed the 3 bolts for the lower unit, it came down a inch or two then seemed supended by the shif arm? If this is right how do you get it disconnected from lower unit?? I should have asked all this before I started. Thanks for our help.
  #4
Old October 12th, 2008, 12:02 PM
Only two bolts for the lower unit. One at the front, one at the back. You disconnect the shift by removing the rubber plug/grommet on the motor leg, then loosen the bolt that holds the upper and lower shift rod together. Now here's the lecture part....Service manual, service manual, service manual. It will prevent you from making costly mistakes if you do your own repairs
__________________
Elvin
My Three Rules:
  #5
Old October 12th, 2008, 12:10 PM
We must be talking about different motors. the shift lever is 1 piece?
This motor seems like a heave duty type? it does have 3 bolts that hold the lower unit on. The guy I got it from said he thinks it's like a larger hp but de-tuned? it is much larger than a 5hp merc I had before.
  #6
Old October 12th, 2008, 02:02 PM
I think you must have the 2 cylinder domestic Mercury....I was referring to the one cylinder Japanese model. Ignore my procedure as it is obviously incorrect for your model.
__________________
Elvin
My Three Rules:
  #7
Old October 12th, 2008, 11:13 PM
Yes 2 cyl. Now back to the problem, any help for me? Thanks
  #8
Old October 13th, 2008, 09:34 AM
Outside of my area of expertise..Sorry.
__________________
Elvin
My Three Rules:
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
help to remove lower unit on johnson 1998 225 removal microeng Johnson & Evinrude Outboards 5 June 11th, 2005 01:24 AM
1998 Mariner 30 hp lower unit repair Raybiz Mercury & Mariner Outboards 4 July 25th, 2003 07:51 PM
84 Evinrude 6hp lower unit removal 83SanDimas Johnson & Evinrude Outboards 3 July 19th, 2003 06:18 AM
yamaha 6hp lower unit removal BIGKASH Yamaha & Suzuki Outboards 1 June 12th, 2003 05:23 PM
'68 ?? 6hp evinrude lower unit removal z-man Johnson & Evinrude Outboards 6 July 16th, 2002 07:03 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
