I pickup this boat, motor and trailer this summer. Trailer was in pretty good shape. The boat , 18' BlueFin, was gutted. Have refurbished. Now I'm down to the motor. It has set idle for 8 years. Cleaned it up, took filter and gas pump apart and cleaned. It looked good. Gas lines are soft, flexable and look like new. Carb's look clean and leankage works good. Plugs look good [.040] did not replace. Compression of 130 psi in each cylinder. Bought new gas line assembly. Blub pumps up hard. Using fresh 50:1 mixture.
When starting, engine starts and runs for 2 to 3 seconds and then quits. It sounds like it is running good, but then just quits like it is starving for fuel. Thinking of getting a carb kit. Appreciate any help. Thanks!!
Navyblue
Navyblue
