  #1
Old October 10th, 2008, 01:37 AM
TN-25's Avatar
TN-25 TN-25 is offline
Question Aluminum boat with possible minor hull damage
There is a cartop boat I am considering. When I look at the pictures in the ad something jumps out at me. I can see the upper starboard side of the boat towards the rear appears to be slightly pushed in. Looking at another photo I can see a slight distortion of the gunwale extrusions at that place. The boat is all aluminum of stretch-press construction, having a seam only at the keel. The seller did not bring attention to the minor damage in the ad nor did he hide it, however he is describing the boat as “perfect”. Have a look at the attachments.
My question is can something like this be easily repaired? It does not look like there are folds in the metal, just a little “wow” on the side, and of course the gunwale. The gunwale extrusion makes me a little uneasy since I believe it contributes to strength in the hull. Should I not consider the boat, or offer something low for it?
Am I making too big a deal of it? I would like to fix it if I decide on the boat.
My dad I believe had the same brand of boat (Nalco) and it was very good. He fell off a roof, landing on the boat and broke his pelvis in the fall. He did similar damage to the boat but more severe; it was still seaworthy (he gave the boat away to a duck hunting buddy).
Thanks for any opinions or assistance.
__________________
Cam Milne
"None of us is as smart as all of us"
  #2
Old October 10th, 2008, 07:30 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: Aluminum boat with possible minor hull damage
looks like it bumped a dock pretty hard, i would say not damage done other than cosmetics.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old October 10th, 2008, 10:20 AM
eavega's Avatar
eavega eavega is offline
Boat brand "Nalco" or "Valco"?
I have an ooooold Valco boat (14') that I picked up on ebay for like $50. In fact, it cost me more to actually pick up the boat (had to rent a trailer, plus the gas) than the boat itself. This thing apparently suffered a great trauma on one side, like pushed up on a rocky shore which punched through the hull. Since the bottom was still fairly true, a riveted piece of sheet aluminum, some hammering, a couple of braces, and a lot of jb-weld and 3M 5200 sealant later, its doesn't leak a drop. with my 20 HP it planes right up and scoots around the lake at about 25 MPH. I have determined that those aluminum rowboats are pretty much indestructible.
-E
  #4
Old October 10th, 2008, 01:09 PM
AZMinyard's Avatar
AZMinyard AZMinyard is offline
The first pic looks like he blurred the image to cover up the boat numbers, may not be actual damage. The second one looks cosmetic, as TD said.
In the end, you will have to check it out in person and go from there.
I paid $175 for a 12' Chrysler that wasn’t nearly as pretty. The guy could have made more off it by taking it to the scrap yard. Lucky for me he didn’t think of that. I did end up putting some cosmetic and leak-proofing work into it, but am extremely happy to have it.
I have heard that the older boats are made out of a thicker gauge aluminum and as a result more resilient and heavier. This might be a good reason to look at it seriously versus a newer boat.
Good luck, be sure to let us know how it turns out!
  #5
Old October 10th, 2008, 01:29 PM
Joe Dirt's Avatar
Joe Dirt Joe Dirt is offline
Looks cosmetic to me. Funny- I thought that it looked exactly like my old Myers- same pattern on the rail, same style of stern, same colors on the floor, same stuff... That boat was bulletproof, aside from having to toss some sealer on the bottom rear rivets after 30 years. I'd rock that boat... Looks good to me!
__________________
1967 Sears 14' V-hull with full redneck bass boat conversion! Fitted with a repainted 1975 Johnson 15HP, and Evinrude bow mounted foot controlled trolling motor...
  #6
Old October 10th, 2008, 02:07 PM
reelfishin reelfishin is offline
I just walked away from a deal like that, the guy said the boat was in A1 shape yet when I went to look at it it had a bellied in right gunwale rail with a crack in the upper extruded rail. There was also various other dings and a few cracks in the corners of the seats. He was stuck on $100 for it. The way I see it is there is no shortage of small boats out there, why settle for one that will never be perfect or one that will require more money to make it 100%. The one I looked at was a very early Sears boat, I ended up answering an add on CL and picking up a mint clean version for the same money. Its the 14 to 18' boats that seem to be hard to find. 10 and 12' boats are all over the place with an average price of about $200 here lately.
When it comes to damage, I'd rather patch a hole than deal with a broken gunwale rail. Its tough to make a repair on that type of extruded tubing and make it as good as new and to hide the repair. Even when welded, aluminum doesn't have the same strength or temper it did when new. Additional material must be added to regain the full strength again and to prevent it from failing in the future.
I'm not saying that boat isn't very usable, but it will take more than it's worth to make it right. If cosmetics aren't an issue, it's probably fine.
The port side blur looks to be just that, a spot on the pic where the seller scrubbed off the numbers for listing purposes.
  #7
Old October 10th, 2008, 02:18 PM
thefishinguy thefishinguy is offline
that doen't look to be anything that should be worried about unless you want a perfect boat. Everyone is right though 10 to 12 ft boat can often be had for little or no money. Just a word as i have had about 10 old tin boats be carefull of the seam in the center. They often split/ pop rivets if over powed or run hard in rough water, just look it over to make sure it already hasen't been fixed because usually its not done right and its a lot of work to fix someone elses mess and may not be worth it to repair.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Through hull fittings on an aluminum boat. newbster Boat Topics and Questions (not engine topics) 4 August 8th, 2008 07:53 PM
Minor (?) prop damage ilmostro99 Prop Questions and Topics 5 May 6th, 2008 09:14 AM
1992 Aluminum Boat needs a good cleaning of the Aluminum Hull What works best?? sigarmsp226 Boat Topics and Questions (not engine topics) 10 December 15th, 2007 07:35 AM
ground to hull on aluminum boat? BF Electrics, Electronics and Trolling Motors 7 April 26th, 2007 01:48 AM
minor keel damage- what to do? mattttt25 Boat Topics and Questions (not engine topics) 9 April 6th, 2005 02:49 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
