Well here is what I have right now, and I will provide more info. when I get it later on.
My fire dept. had a boat donated to us from a bank, we live on the Ohio river so we need a good boat. The thing is, since we have had this boat we've put about $10,000 in it to rebuild the motor and a new paint job. Well the motor still isn't' running correctly. I will have to find out what all was done to it but I do know its still not right. I believe the boat is around 22'-24'. We had an electric fuel pump installed on it because the mechanic said it was starved of fuel. Well after still not running right for year, some of us decided to start messing with it ourselves because we've spent all of this money on a "free" boat. We recently change all the plugs and took the electric fuel pump of.
When trying to start the boat it smokes like crazy, and when it actually starts and you have the gas 3/4 throttle it will idle up really high then back down and back up again for about 20 minutes. We took it out when it started to run pretty good and after it kept taking off and slowing down (while the shifter was full throttle) it finally took off and we ran 41-43 for about 20 minutes. It started up fine if we shut it off but still wouldn't take off fine. One week later we took it out again and it ran like crap again do the same thing all ovre again.
Sorry I don't have all of the details yet but I am working on getting them. I was just wondering if I could get a few pointers to look into for now. We really can't afford to take to more mechanics with our budget.
Thanks.
Oh yeah, it also seems like it should be putting out a stonger stream of water when it actually runs. I'm guessing impellar but will that make it run bad? It is a steady stream coming out, but the other guy on the boat with me said his Johnson 70 has a stronger stream.
Thanks.
