fireman_bob
- Mar 16, 2008
- 100
Hi,
I've got a 2000 200hp ficht that frequently stalls during shifting. Occasionally I also get a Code 28 (neutral safety switch). Can someone please explain the proper procedure for adjusting the shift linkage? I think my cable may be stretched a bit and I would like to be sure this is correct before replacing the switch (the switch appears to work fine on a meter when shifted by hand).
Thank you.
Thank you.
