Re: Look what I found in my exhaust tube!!
Yes, you can put the drive back on. Difference in heat is probably due to water flow restrictions. You may ALSO have a plugged riser. That piece of flapper is a significant restriction. I'll bet that once you get them replaced, you'll notice a big difference in power.
Since I have NO IDEA what boat you're working on, I can't tell you where the flappers are. Since you mentioned 2 different manifolds, I feel it's safe to assume you've got a V-8 or V-6.
If you're lucky, and have a newer exhaust system, the flappers will be at the top of the Y-Pipe, just below the risers.
If you're unlucky like myself, and have an older boat, the flappers will be at the base of the Y-Pipe, where each side bolts to the transom plate. There are 3 Allen Bolts on each pipe, which will have to come out. You MAY be able to get them loose without removing the engine, provided you've got some nice long Allen Sockets, and plenty of room to get into the bilge. If not, you'll have to pull the engine.
Either way, the risers are gonna have to come off, so you might as well check the top of the Y-Pipe first.
Do you have the proper manual for your boat?
