E200TXEO 25" shaft. drained gearcase oil while contemplating another problem and discovered water in oil. Removed lower unit and put on bench for re-seal job. Looked up seal kit on BRP website. They show an early production double seal 0434516 and a late production single seal 0437753. Can anyone tell me how to determine which kit to use?
Question: is it necessary to disassemble entire gear case to reseal? I'm trying to get a jump on it before manual arrives. Is there anything I should be aware of if I attempt this? I was looking at the output shaft and it looks like a bearing carrier has the seal in it. can I just remove the two bolts and tabs and slide that assy out or should I wait for the manual?
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
Re: 1995 200 Evinrude Gearcase w/water
The difference in the drivesgaft seals is (if I remember right) the early production used 2 back to back seals, the late production used a double lip seal.
You don't have to take the bearing carrier out if you have the seal removal tool. Yes, the bearing carrier should come out if you remove the bolts. You'll probably need the puller (not on a counter rotation drive though - just in case someone has switched yours) and if it's been in salt water you may have to use heat.
Thanks. I put about 10 to 12 psi on it last night and it was bubbling water at the input shaft seal. I don't have a vacuum pump. I suppose I could borrow one from work.
