I have a 1988 SeaRay Seville with a 135HP Merc V6. It usually starts fine and runs fine all full speed but it doesn't want to run at idle. I was on the water yesterday and I could put the engine in neutral, rev it a few times then quicky put it in gear and it would be ok but if I tried to let it idle it would just die. I'm not totally, sure but it seems to be worse right after the engine has been in the up tilted position( ie while towing, or beached ) and it seems to work somewhat better after it has run for awhile. Also, one time yesterday the engine died while at idle and didn't want to start again. I eneded up squeezing the fuel line bulb a few times and it then started.
Any help would be greatly appreciated.
Mark
Mark
