  #1
Old October 5th, 2008, 11:04 PM
boaternewbie boaternewbie is offline
Default 5 hp Mariner Overheats at Idle/Low RPM
Hello-
I recently purchased a little 1987 12 ft aluminum boat with a 5 hp Mariner 2 stroke motor. I have taken it out twice in the 4 days I have owned it and have a couple questions about it as I am an idiot to this stuff. All advice and thoughts are much appreciated.
I starts great. One pull. And seems to idle and run just fine, however I have to high rev the engine for several minutes to get water to come out the tell tale. I then have to continue to hold open half throttle to keep the water coming. When I let off the gas water stops "peeing" out the tell tale and it turns to steam or nothing. Once it stops I have to put it in neutral and high rev the engine again to get it to start peeing out again as giving it more throttle in gear doesn' do the trick.
Like I said I am an idiot and only know the word tell tale becuase I read it on some posts.
I appreciate anyone who can help me.
Thanks
  #2
Old October 5th, 2008, 11:10 PM
emckelvy emckelvy is offline
Default Re: 5 hp Mariner Overheats at Idle/Low RPM
Sounds like the impeller has lived a good life and is ready for its voyage to the Great Beyond! The fact that it won't pump a good stream at lower speeds indicates a drastic loss in pumping efficiency (i.e., it's shot!).
Seriously, pull that baby down and replace the imeller. If it's been more than a couple of years, or you don't know when it was last replaced, it's time.
You can look up parts at various places including the iBoats store, if you can't find what you need try here:
http://www.mercruiserparts.com/Selec...asp?class_id=2
HTH.......ed
  #3
Old October 5th, 2008, 11:39 PM
Thanks for the reply Ed. Understand I am like a kindergardner to this. Could I trouble you to tell me where or how I might learn to replace the impeller? Also, do you know a rough price range and amount of time it takes. Sorry for the hassle, thanks for the response.
  #4
Old October 7th, 2008, 01:52 AM
Check out this past post for some good generic info on impeller replacment.
http://forums.iboats.com/showthread....+replace ment
Check out the link within the above thread and there's a real good rundown of how to replace an impeller on a larger motor. The general stuff still applies although it'll be a tad simpler on your little 5HP.
Use this forum's search feature and you'll find lots more.
Note impellers are generally not that expensive, can't give you specifics without a serial #. I'd recommend looking up your motor at the link I previously posted and you'll not only get good parts info but also illustrations showing how your motor's lower unit hooks up and whether or not you'll have to deal with a shift shaft.
HTH...........ed
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
100 HP Mariner 1989 Idle RPM What should it be? w2much Mercury & Mariner Outboards 6 March 4th, 2007 11:01 AM
1988 15 hp johnson low rpm idle problem BILLYP Johnson & Evinrude Outboards 3 March 24th, 2006 11:29 PM
Mariner 50 overheats at high RPM McGurk Mercury & Mariner Outboards 2 June 18th, 2004 04:24 PM
Mercruiser engine overheats when at idle or low running speeds RookieAlphaOne Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 18 June 9th, 2004 01:08 AM
1986 Mariner 50 HP overheats @ high RPM McGurk Mercury & Mariner Outboards 0 July 11th, 2002 09:35 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
