I?m almost done with the work on my old Johnson. It is a 1965 Johnson 60HP VXL-11C. Can any one tell me where the water pump impeller is located and what is the easiest way to access this? This is the last think I have to check before i hit the water. But before I tear into the lower unit Im going to test the impeller with the water ears that connect to a garden hose. My problem is I can't find where the water is pulled into the motor. Where do i connect the water ears. Thanks in advance
