When you squeeze the gas line primer bulb, are you providing unmixed gas to the carbs?
Another question: Say your vacuum pulse becomes reduced due to a faulty vro air pump, or due to an excessively worn engine that produces weak vacuum pulses from the crankcase. You have a friend pump the gas primer bulb to get up on plane, do some fishing, and head back in to shore. Will your oil/gas mix ratio be the same as if your vro and engine were operating normally? If your vro air pump were totally dead and delivered no pulses, would just pumping the primer bulb fill the float chamber with a correct oil/gas mixture?
As I understand it, gas and oil are both pulled into the mixing chamber by a single piston operated by the air pump from vacuum pulses. When you pump the primer bulb, does all the incoming gas from the primer bulb push that piston pulling the correct amount of oil into the system? Or is some of the primer bulb gas able to bypass the piston resulting in a dangerously low oil to gas ratio?
