Mercury 115 idle/acceleration problems
thefaulk
I am having a few problems with my late 70's Mercury 115 hp motor I was hoping someone on here could help me out with.
Since purchasing my boat, I have had nothing but issues with the boat starting, running and accelerating. It always needed to be fed fuel via carbs to start and once it was started it would not idle until the mechanical advance was pushed about halfway up, making it idle at around 1,200 rpms. Also, when accelerating from a dead stop, the boat would accelerate slowly and sluggishly to about 2,800 rpms and then sort of float out at 2,800 rpms until the boat was turned side to side, then it would snap out of it, continue accelerating all the way up to 5,000 rpms and hold it all day long.
I decided after failing to pull skiers and knee boarders successfully to remove the carbs and clean them. The filters had some crap in them and there was a little sediment in the bottom of the float bowls and after I cleaned everything and re wired part of the engine (there were some cracked wires I found when removing the carbs) the boat started and idled pretty good on the hose in the driveway. When I got it on the water it ran pretty decent...better acceleration, easier starting, even better idle...until it warmed up. Then it became hard to start again and acceleration wasn't there nearly as good as it was when it was cold (when accelerating hard from a dead stop, sometimes it will pick up and go fairly good, good enough to pull a knee boarder, and other times it will fall on it's face and die) and idling wouldn't happen unless the mechanical advance was 1/4 of the way up.
Sorry this is so long but I am really getting fed up with this damn thing because I am spending more time fixing it than I am enjoying it with my family and friends! Any help would be greatly appreciated!
Laddies
Banned
Re: Mercury 115 idle/acceleration problems
Did you clean the tanks or install a spin on fuel filter in the line, both might have helped
Yepblaze
Perhaps one or more carbs is flooding out a bit. Try changing the needle/seat assemblies.
That would make idling troublesome and would take some time to clear as you run up.
It's also possible for a float to become heavy and not actuate the needle/seat well, but I've seldom replaced floats. Needle/seat assemblies are pretty cheap (comparatively speaking) All you need is the time, as it looks like you have experience now.
You will also need to check the float adjustment (level on the float arm when inverted I believe), and dial in the mixture screws again.
PS they do start hard (hold the choke on till it runs) and usually require the warm up lever to get going.
___________________________________________-
Best of luck and don't hold it against me if it doesn't work. It's what I'd do.
thefaulk
When I had the carbs apart the floats looked good (they are clear plastic) they didn't have any fuel in the and seemed to freely move up and down in the float bowl. I will change the needles and see if this helps. Thanks for the advice.
Also, I just did a compression test and all are showing about 94-96 lbs. except number 5, which is showing 105 lbs. What is the proper compression for this engine and why would one be more than the rest?
Yepblaze
Gauges vary so much that the numbers should only relate to themselves.
All within 15% is OK
All within 10% is better.
