  #1
Old October 5th, 2008, 02:07 AM
Mizee Mizee is offline
Send a message via Yahoo to Mizee
Default Bow mount Minn Kota
I have a bow mount Minn Kota Edge 40lb thrust. Took it out on the lake, everything worked fine for about 5 minutes on Constant troll. I switched it over to Momentarily and nothing happened. After messing around with the foot control for about the 30 minutes it came back on just laying there for about 2 minutes and then stopped again. Could this be a short in a wire or be a problem with the foot control switch?
  #2
Old October 5th, 2008, 09:26 AM
Silvertip Silvertip is offline
Default Re: Bow mount Minn Kota
It could be the circuit breaker at the battery is tripping because the motor is drawing too much current. Need to know what size breaker is being used. (Should be 40A - 50A.) Remove the prop and check for fish line wrapped tightly around the shaft causing drag. Rotate the prop manually to see if the bearings are tight. Wiring may be too small which heats up and causes high current draw. Motor may be going bad. Cycle the momentary/continuous switch several times as the internal contacts may be slightly corroded.
  #3
Old October 5th, 2008, 12:46 PM
The battery I'm using is a Energize Deep Cycle Marine battery. The only corrosion I found was a little on two screws under the foot control where the switch is for the momentarily switch. I couldn't find where it had listed as a 40A or 50A.
  #4
Old October 5th, 2008, 05:31 PM
The foot switch is not labeled 40A or 50A. There should be a circuit breaker connected to the positive terminal of the battery. That breaker is generally a manual or automatic reset breaker that kills power to the circuit in the event of an overload.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Minn Kota 55 AT bow Mount ScottWilliams MMC Electrics, Electronics and Trolling Motors 0 April 22nd, 2007 02:04 PM
Minn Kota Bow Mount BigTrouble Electrics, Electronics and Trolling Motors 4 May 12th, 2006 08:33 AM
Minn Kota 74# bow mount locking up dfinny111 Electrics, Electronics and Trolling Motors 1 January 5th, 2006 03:51 AM
Transom or Bow mount for Minn Kota Pelicano Electrics, Electronics and Trolling Motors 10 December 16th, 2005 04:57 PM
Help with a Minn Kota bow mount motor jsfinn Electrics, Electronics and Trolling Motors 7 April 6th, 2004 11:36 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
