jeffmyersvt
- Aug 24, 2008
- 2
1985 230 Chevy block Merc. Starts no issue. Stalls after 5-8 minutes at full or close throttle. Re-starts, runs at low rpms fine, will run again at full throttle for another 5 minutes or so before sputtering, backfiring, and stalling again. Thought there was water in the fuel issues, emptied water separator, put in dry gas and went through the full throttle stalling process 5-6 times over a few hours trying to burn the gas out. Removed the fuel line hose from the gas tank, took off the nipple connector to see if the stop/gap ball was in there (it wasn't), removed the pipe from the tank to see if the screen was clogged (no), proceeded to break off the top connector piece when putting it back on (aluminum breaks easily). I've yet to check the filter where the line enters the carb, but it seems somewhere the gas is getting choked. Any thoughts?
