  #1
Old October 4th, 2008, 10:32 PM
bobd1972 bobd1972 is offline
Default sealing aluminum hull leak-pic
Hello I'm trying to seal 2 leaks on my 1983 16ft sea nymph I cirlced in marker the leaks. The first image is the inside of the hull. There is a rubber sealant present. Do I remove this and add gluvit to the seam? The second pic is on the outside of the hull directly below the spot on the first pic. There is another leak circled on the lower right hand side. There is no rivet there but there is a cross member directly above it.
bob
  #2
Old October 4th, 2008, 11:24 PM
Stoutcat Stoutcat is offline
Default Re: sealing aluminum hull leak-pic
Hi Bob,
We have a '57 Starcraft that had a leak around the drain plug. We looked at two solutions, and went with the latter. (No matter what you choose, practice on scrap first)
i.) Dura-fix... A low heat aluminum weld
ii.) J-B Weld... An epoxy/steel mix... (That worked very well, and is applicable to aluminum)
Alan
  #3
Old October 5th, 2008, 12:53 AM
IWELD's Avatar
IWELD IWELD is offline
I've had pretty good luck with hardware store marine epoxy, the kind that comes in stick. Heck, in a pinch once I used some dough ball catfish bait on a pencil sized hole on a little 14 ft john boat I had borrowed from a buddie. it stayed on for two or three trips!
  #4
Old October 5th, 2008, 10:25 AM
1beanie 1beanie is offline
ive had great results with the gluvit from the inside the hull really seems to get all in the areas that need sealing good luck man
  #5
Old October 5th, 2008, 11:23 AM
Bob_VT's Avatar
Bob_VT Bob_VT is online now
Gluvit is the best solution. You can even paint it on seams. Gluvit "creeps" and remains more flexible than JB weld.
I used gulvit on my 63 Starcraft and basicall kept the hull tilted until it dried (24 hrs) and then tilted it the other way ......... you want the hull positioned to have the gluvit creep into the seam.
__________________
"When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
SpinnerBait_Nut's Member Map Link Please add yourself http://www.frappr.com/iboats
  #6
Old October 5th, 2008, 12:01 PM
BillP BillP is offline
Location: Recently moved to high rise waterfront condo on Pluto. What a view!
When using Gluvit for this type application heat (just warm) the area first. It will thin out the Gluvit and let it penetrate deeper.
  #7
Old October 5th, 2008, 07:55 PM
Thanks for all the advice. Does anyone think I should try to tighten the rivets? There are some rivets that seem pretty worn on the heads. Do I dare try and replace them? I like the gluvit idea I'm not sure if I can angle the hull(heavy) to get it to run in the seam, but I'll try.
bob
  #8
Old October 5th, 2008, 09:38 PM
BigB9000 BigB9000 is offline
Send a message via AIM to BigB9000
Henry's.
(roofing tar. The colder/wetter it is, the stronger it is)
It looks like crap, but when your out in the middle of a lake and spring a pretty good leak (actually was already there, just never had the boat in the water before) It comes in handy, and will will swear my it from then on
  #9
Old October 5th, 2008, 11:11 PM
If you know how to buck rivets then go for it...othewise pop rivets work but need sealing. Most in my neighborhood repair alum using pop rivets with 3m 5200 plastered on the inside. If using an alum patch with 5200 under it you won't need fasteners. There are a lot of ways to do it but welding is the best if you can find a local shop that does alum.
  #10
Old October 6th, 2008, 09:52 AM
Ned L's Avatar
Ned L Ned L is offline
The simplest way I used to fix such problems (& always had good luck) was to wire brush the area so it is all bright & clean & then work in silicon caulk, the $2-3 clear stuff in a tube is fine. You don't need a thick layer, work it into the seam & around the rivet with your finger & then just a thin layer on top does it. -- Any of the above methods work too.
  #11
Old October 7th, 2008, 01:30 AM
Nova II 260's Avatar
Nova II 260 Nova II 260 is offline
Clean, clean and clean the area is the key to any good seal. Whatever product you're going to use.
(posted elsewhere on iBoats)
I've used Lab-Metal by Alvin on my aluminum Tracker (old transducer holes and such)
A bit expensive but, works really well. Easy to work with, paintable and lasts forever. Be sure and follow the instructions.
Bought it at Fastenal But should be available at any welding or industrial supply house.
__________________
The Lead Dog has the best view.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Sealing Aluminum Hull With Poly Resin? cprince Boat Restoration and Building 9 September 19th, 2008 09:01 PM
rivited Aluminum Hull Leak detection Wilsonriverfisher Boat Topics and Questions (not engine topics) 0 April 1st, 2008 11:03 PM
Sealing chips in hull? MiKeC. Boat Restoration and Building 6 June 21st, 2007 08:43 AM
VP 4.3GL-PEFS 2000 - Sealing Question with pic cmyers_uk Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 March 24th, 2007 10:23 AM
Sealing the bottom of an aluminum jon boat San Antonio Cop Boat Restoration and Building 9 December 14th, 2005 03:13 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
