  #1
Old October 4th, 2008, 06:49 PM
Donger Donger is offline
Default 1985(86?) 115 mercury powerhead Question
I have a 115 1985 or 1986 mercury. i have a blown piston in no.5 and the piston is locked in the cylinder. Is there any interchangable powerhead for this motor. If not, can i resleeve the gouged cylinder? I have been browsing the internet for motors and have seen some online that are 90 hp mercury motors that look as if they are the same as mine. I wonder if i can get a 90 hp head and use that.
Thanks in advance for the help.
  #2
Old October 4th, 2008, 06:58 PM
achris's Avatar
achris achris is offline
Send a message via Skype™ to achris
Default Re: 1985(86?) 115 mercury powerhead Question
The 90 block is different. It doesn't have the power ports that the 115 block has.
I would just knock out the old piston and have that cylinder bored. Unlike 4 stroke engines, it's ok to only bore one (or two) cylinders on an outboard engine. Then buy an oversized piston for that hole.
Chris............
__________________
The world takes on a whole new perspective when viewed from 100' below...
1972 Bertram 'Bahia Mar' 20
2006 Mercruiser 4.3MPI (OW617679) w/Alpha 1 Gen II (OW829301)
  #3
Old October 4th, 2008, 07:14 PM
Chris, I think the damage is beyond boring the cylinder out. Do you have any specs on the total boring potential in that cylider? The piston is cooked to the block and has gouged the walls badly
  #4
Old October 4th, 2008, 07:22 PM
achris's Avatar
I don't have personal experience, but I have heard of some machine shops sleeving the block.... The biggest oversize that Merc do is 0.030". That's quite a lot. I think there is an aftermarket piston manufacturer who goes bigger, but k.r.a.f.t. disease has got me again
Chris............
__________________
  #5
Old October 4th, 2008, 09:03 PM
Chris, i have another block for the motor. It has a 16th of play in the bearing end cap and i was told that that could be welded with aluminum and machined down to proper specs. Do you think that this is an easier approach to the issue than trying to bore out the block. i talked to the dude that i took it apart with and he said it wad f$!%ed. The other block it gouged pretty bad
  #6
Old October 4th, 2008, 10:15 PM
achris's Avatar
If the crank, with rods and pistons, on the current block is ok, and you don't want to use it, then put them into the new block. Just be sure to keep the crankcase covers for each engine together. They are a machined pair. You can't use cover 'a' on block 'b'....
Chris.............
__________________
  #7
Old October 7th, 2008, 10:06 PM
daveswaves's Avatar
daveswaves daveswaves is offline
Well Donger you have a couple of options. Chris is correct, the 90 hp is not power ported. You can certainly bolt a 90 hp block on your lower end no problem, you just won,t have the power you used to. Getting back to your 115 block. I have personally rebuilt a few of these and I would be surprised if you could not bore out the one bad cyl. Pistons are available up to 30 over and the weight difference of the new piston is negligible. If you have not pulled it apart yet you will find that it is not going to go together that easy once you do, its truly a labor (labour) of love to rebuild. Complete rebuilt powerheads are available on ebay and unless you are quite adept at rebuilding I would suggest that is the route to go. If you decide to rebuild gasket sets and pistons are available on ebay. Your crankshaft with the 1/16 journal play sounds like it is toast.
If you are going to bore the block you will have to find someone who is willing and capable of doing a "blind" bore. There is no removeable head on that block so it a little tricky to bore.
  #8
Old October 8th, 2008, 07:11 PM
hamit59 hamit59 is offline
Send a message via MSN to hamit59
As a machinist, I'll tell you Mercs are a real pain to bore. The liner is case in place, so you can't just bore it out and press in a new one .
I have bored over 50 j- rudes but my machine does not do blind bores.
I refer all the mercs to a old machinist the does then on a mill, he charges by machine hour @ 75.00 hr setup runs around two hours per hole, if it's not egg shaped real bad. A .030 oversize bore is very thin cylinder wall on a merc and some are chromed as well so you loose all your chrome.
If you don't have a good Marnie machinist in your area. I would look into a reman power head
Out of round limit as by the book is .0075 max and they do sale a .030 oversize piston, but I would never go that far with a oversize bore.
Just my 2 cents worth
Hamit
BT1 USN ret
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1985 Mercury 115 hp power loss 85Lund Mercury & Mariner Outboards 27 May 10th, 2009 12:28 AM
Difference between '81 & '86 Merc I6 115 powerhead? gregpro50 Mercury & Mariner Outboards 2 June 17th, 2008 04:44 PM
Mercury I6 90 & 115 HP powerhead differences gregpro50 Mercury & Mariner Outboards 4 June 16th, 2008 04:00 PM
1978 Johnson 115 Powerhead question honkytonker26 Johnson & Evinrude Outboards 3 April 3rd, 2007 08:27 AM
Mercury 115 hp powerhead question sdgs Mercury & Mariner Outboards 0 June 15th, 2004 04:23 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
