Ok i got the motor in the water (trash can) today with fresh seals on the lower unit, new impeller, and a new starter pinion. ready to test it out.
started up after a few pulls and ran a little rough, but it finally warmed up and started sounding better but i ran into a problem.
it runs fine and dandy idling when the motor cover is off, but when I put it on it will die when trying to idle. i tried adjusting the richness setting, but i honestly dont know where that is supposed to be.
what is usually the problem if it wont idle with the motor cover on vs off, and where should my air / gas mix setting be at?
obviously it is needing air that its not getting, but dont know the cause.
thanks
thanks
