Hello, Recived my new Teleflex Tach today. The instructions are a little to be desired. I own a Johnson 1980 70 Hp 3 cyl. The diagram shows a connection to a grey wire somewere between the command control and the motor,then connecting to a wire that says any yellow, finally to a wiring block that the only thing in english is red ? go figure. The next problem is should I connect in the command control or the motor ? pro and cons?
Thanks for your help and Happy Boating
John
John
