30hp Johnson, yr 94
arsvcs
The motor was not pumping water out. I have replaced the water pump and propeller, still not pumping out water. Replaced gaskets also. Any ideas?
tx1961whaler
Re: 30hp Johnson, yr 94
Is the motor running hot? Sometimes the cooling system is working fine, but the tell-tale ("Pee stream") is clogged. I have mud-dauber wasps around here that plug up everything with a hole in it.
david_r
when you reassembled it did you make sure you got the pick-up tube back together?
i did mine by myself and had a little trouble lining them back up together while holding the lower unit up.
did you put the water hose or compressed air to the water pick-up tube to make sure there were no blockage?
