Doing a refresh of my dads old boat. Was running great as of 2 weeks ago (no really, it was) While going to replace the fuel lines and broke a nipple. Got the fuel system sealed back up, but had serious sluggishness. I did a rebuild of the carbs (1986Evinrude 90HP V4 w/ dual 2Barrel) and found on the lower carb a piece of plastic blocking fuel. Did the carb rebuild, put back into the motor, and the sluggishness is gone
....but a new issue came up:
- At idle, it is running super fast now (2,000 rpms) and surging
- I adjusted the idle all the way down, while looking into the carbs to see how open they were. The top carb is not fully closing, while the bottom one is closed all the way...idle still is 2k.
- While running in idle, I manually push on the linkage so the top carb so it is fully sync'd with the lower carb (closed as it should be at idle) This smooths out the running, slows the idle to about 1,000-1100rpms
- I have tried to adjust the linkage to bring the upper carb all the way to the closed position, but its clear the spring isn't pulling the carb all the way closed. any ideas? (is this a linkage problem i haven't figured out yet, did I bend the spring possibly, etc?)
- is this my only problem, or did i rebuild the carb wrong?
Thanks for any help This is my 1st real work on any outboard engine.
