  #1
Old October 1st, 2008, 09:18 AM
JiminOka JiminOka is offline
Default Mercury 45 hp won't shift - stuck in gear?
Hi All: I have a Merc classic 50 that seems to be stuck in forward. I searched the forums but either didn't find what I needed or didn't make sense of it (sorry).
My questions:
1. What is the most likely cause?
2. How difficult (or expensive) is this to fix?
Many thanks,
Jim
  #2
Old October 1st, 2008, 12:29 PM
Yepblaze's Avatar
Yepblaze Yepblaze is offline
Default Re: Mercury 45 hp won't shift - stuck in gear?
Most likely,
Perhaps someone has removed the lower unit, like to do a water pump impeller service, and not aligned the shifting splines correctly when they put it back together.
Beyond that there are a number of other possible issues that could cause loss of shift control.
Such as, but not limited to,
Cables, cable connections and supports, controller, broken or rusted away components, human error from previous repairs, etc.
I suggest, if you are unable to look it over and see if all the mechanisms are working, you have it looked at professionally.
Some shops might give you a free estimate, otherwise expect to pay $80-$100+ an hour for services, plus parts.
  #3
Old October 1st, 2008, 12:53 PM
Thanks for the quick response.
The motor was working fine -- then suddenly this happened. The lower unit has not been off.
I had a shop (non-Mercury) check the control and cables and that seemed fine. They just weren't sure what to do next -- nor was I.
Again, thanks for the response.
  #4
Old October 1st, 2008, 02:13 PM
Yepblaze's Avatar
You will have to work from one end to the other.
Me, I'd start by looking to see that the appropriate cable is actuating the mechanism under the hood. And if that looks good, I'd be dropping the lower unit and seeing if it were functional.
It is possible that something broke or rusted away between the two areas, but you, or a mechanic would have to delve in to see.
  #5
Old October 1st, 2008, 03:21 PM
Okay, will do.
Thank you.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
45 hp gear clunking... conor1366 Force & Chrysler Outboards 0 June 25th, 2008 09:27 PM
Shift rod stuck in gear case snowy23 Johnson & Evinrude Outboards 2 March 24th, 2007 07:50 AM
45 HP Mercury, won't shift right, please help boatsalotjay Mercury & Mariner Outboards 2 May 2nd, 2004 07:14 PM
45 HP Mercury Stuck in Forward Gear jknowles Mercury & Mariner Outboards 2 May 7th, 2002 06:31 PM
Mercury 7.5 gear shift stuck David Walker Mercury & Mariner Outboards 1 April 23rd, 2002 02:32 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
