rebmo
- Jul 2, 2007
- 60
I have a 1972 50hp Johnson Anniv Ed with very low hours on it and it has run great up until today. The only problem I have had was gunked up carbs, which I rebuilt a couple years ago. I started with the muffs 1 month ago and it fired first crank after sitting all winter(WI). Today I took my wife and son to go fishing on a local lake and all it would do is crank over with no sign of firing. Fuel was getting to the plugs and carbs. I bought a fresh tank of fuel filling my other empty tank, no luck. I pulled a plug and grounded it and there was no spark. Usually it puffs exhaust if it takes a few revs to start, but no exhaust, just fuel smell and some leaking down into water.
Anyway, I have had issues with the muffs and starting and cranking long, but I wrote it off to an old battery and after trying later it started. I never had it die at a lake, but only use it a couple times a year. I did replace one coil that was cracked but working fine, and checked the stator and it has no leaks and looks like new. I'm wondering if it is the power pack like yours, and how do you tell.
I would describe my issue as a no spark intermittentlyin the past and now there is no spark after several attempts.
Power pack? How do you tell? Other electrical parts?
Thanks,
Steve
Thanks,
Steve
