Re: Idle Adjustment Suz 70HP 4 stroke
As of now, have service manual, have fast idle at start that drops when engine warms up, power all 4 cyls, this seems OK. With hose disconnected and pinched ide set to 1000 rpm in neutral. Reconnecting hose engine immediately stalls and shuts down. I expected rpm to drop to 750 and continue to run. How do I clean the IAC? I removed the IAC, sprayed choke cleaner thru both hose connections, small amt of black debris came out lower connection, top connector clear, blew thru rubber hose, unobstructed, I only wiped off the round olive drab (IAC valve?) electrical piece removed. Should I have done more? How? It appears one needs to connect a wiring harness to the black box to get error msgs and then have programs to reset computer to correct msgs. Correct? Did not realize a Suzuki & Rude similar. Will visit Rude dealer. Don't know what ECU is. Will read up on that. Apprecite everyone's help and ideas. Will measure twice and cut once. Thanks.
