  #1
Old September 29th, 2008, 08:50 PM
stormiespop stormiespop is offline
Default 50 hp Yamaha 2-stroke hard to start
Hello, I have a 50 HP Yamaha 2-stroke that is hard to start after it has been sitting for just a couple of days. Once it has been started, it will start fine all day and runs fine. I squeeze the primer ball until it is hard and it has plenty of gas. The engine is only a year old.
  #2
Old September 30th, 2008, 03:17 AM
deejaycee_2000's Avatar
deejaycee_2000 deejaycee_2000 is offline
Default Re: 50 hp Yamaha 2-stroke hard to start
sounds like your starting procedure is wrong ...... after the bulb is hard you must pull the choke untill it fires up, then you push the choke back and fire it up again ... then you are good to go ...
__________________
__________________________
... THE MAXIMUM HORSEPOWER IS NEVER ENOUGH ...
  #3
Old July 18th, 2009, 10:40 PM
T Berry T Berry is offline
Quote:
I also have a 50 hp yamaha that is very hard to start after it has been sitting for a day or two. I was told that my 2003 had a choke that you are suppose to turn the key one click prior to trying to start and that this key position was the choke. I have not had any luck on fiquiring a easy way to start it. I was wondering if you ever fiquired out a way to start it easy.....sure is embarring sitting at the doc and cranking and cranking and finally it spits and sputter and cuts off but when I crank it over a gain it starts up and runs fine for the rest of the day....My problem is I don't have a local yamaha mechanic to take it to have fixed. Looks like I'm probably going to take a 2 hour trip to get mine to the shop. Hope you had better luck in fiquiring out a easy way to get yours started.
  #4
Old November 14th, 2009, 09:17 PM
billinkansas billinkansas is offline
You may have the Prime Start feature on your motor.
Try this, works great on my Yamaha 90 that I used to have trouble with:
Prime the bulb very well.
Leave the throttle all the way closed.
Crank the motor for 4-5 seconds - it may start
If not, wait about 5 seconds and crank again, should fire right up.
The key is to leave the throttle closed. Don't bother trying to choke because there isn't one.
Good Luck!
BK
__________________
BinK
1986 16' Wahoo side console with 2006 Yamaha 90hp 2 stroke.
  #5
Old November 15th, 2009, 10:50 AM
rodbolt rodbolt is offline
what billi says.
make sure the manual overide is not in the closed position.
if it still wont start correctly the lync and sync may be incorrect or there may be a fault in the prime start system.
but any throttle opening will render the automatic enrichment circuits inoperable.
  #6
Old November 16th, 2009, 02:36 PM
ubetcha ubetcha is offline
I have a 2-stroke 25hp Yamaha, same hard starting [15-20 pulls when cold, then started easily for the rest of the day]. Problem was that in the start position, the throttle arm did not engage the linkage on the carbs. Adjusted it so the carb linkage is slightly engaged in start, and the problem was corrected.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 30hp 2-stroke, hard 2 start allymoss Yamaha & Suzuki Outboards 0 August 19th, 2007 02:37 PM
1999 9.9 HP 4 Stroke hard to start. Worm Drowner Mercury & Mariner Outboards 0 May 7th, 2007 01:05 PM
50 Yamaha 2-Stroke start-up KWolfe Yamaha & Suzuki Outboards 9 June 18th, 2006 10:56 PM
hard to start 1972 50 hp evinrude ratt1966 Johnson & Evinrude Outboards 11 July 17th, 2005 01:57 AM
Yamaha 50 horse 4-stroke will not start shurkis Yamaha & Suzuki Outboards 13 March 4th, 2005 01:38 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
