  #1
Old September 29th, 2008, 01:45 PM
paul_614 paul_614 is offline
Default 1974 15 hp Evinrude electric start
I am not able to get the motor to shift. I had it to a "marine" mechanic to get some work done. He did a carb kit and replaced the impeller. The first time I took it out, it wouuld not start, so I took it to the boat ramp and with the help of a few friends, got it to start, then, while in neutral, it prop would turn as if in forward. We took to boat out of the water and pulled the breather off the carb, we noticed that a linkage was not re-installed, so we do that. Now it will still not shift. The handle moves but does seem like the shift rod is connected to the shaft. Does the whole lower end have to come off to check if the yoke is connected, or can I do it with just the prop off?
Paul
  #2
Old September 29th, 2008, 02:03 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Default Re: 1974 15 hp Evinrude electric start
Your "mechanic?" had to disconnect the shift linkage in order to obtain access to the water pump. Why are you doing his work for him? Take it back and demand to have the job done right.
And there is no need for any shift linkage to be tinkered with at the powerhead area.
The lower unit needs to be dropped down about an inch or so in order to gain access to the brass shift connector.
  #3
Old September 29th, 2008, 02:44 PM
I have taken this issue to my laywer already, from day 1 with him having my boat, he has acted lets just say odd. So I will not have any more dealings with him other than to recieve my money back.
Thank you for your reply
  #4
Old September 29th, 2008, 02:56 PM
Joe Reeves's Avatar
Good for you Paul, glad to hear from one who won't just sit back and take it so to speak. I have no tolerance for incompetence.
The brass shift connector I mentioned secures to the lower and upper shift rod with two 3/8" hex bolts. The groove in both rods must align with the holes in the brass shift connector. If not aligned, the threads on the bolts normally strip somewhat causing the threads on the brass connector to strip also. You and a friend can no doubt handle that job..... align the water tube with the water pump grommet, the drive shaft with the crankshaft splines, and the brass connector with the upper shift rod.
Hint.... have the unit in gear so that turning the prop turns the driveshaft to alingn the splines in the crankshaft.
  #5
Old September 29th, 2008, 04:07 PM
Thank you Joe for all the help you have given. I do believe that read somewhere that it is better to have it in reverse to do this, is this true?
  #6
Old September 29th, 2008, 04:13 PM
d.boat d.boat is offline
Now, I'm all in favor of being assertive to get the work done right, or get your money back...
but unless i'm missing something - why didn't you go talk to the mechanic before starting to spend money on a lawyer? Why the lawyer at this point? Has the mechanic refused to make it right or refused to give you your money back? It seems to me the easiest and best thing would be to simply bring him the motor and ask him to fix it on the spot? It's probably a 15 minute job for a qualified guy. I'm not excusing what the mechanic did or didn't do, but geeze, your first step should be to have him make it right.
  #7
Old September 29th, 2008, 04:24 PM
asdasc's Avatar
asdasc asdasc is offline
Does the '74 have the split shaft like my '59 18HP? If so, you can do it all with needle nose plyers thru the little cover on the side.
Unless of course someone pulled the screw on the bottem which holds the lever that moves the yoke. That is a pain to have to take it apart to that level. Complete dissassembly of the lower unit is required at that point. Never take out the little phillips head screw at the bottom of the skeg.
__________________
Steve
Livin' the Dream
The Black Pearl - homemade pontoon boat - 1958 Johnson 18HP
On A Whim - 1990 ChrisCraft Concept 198 - 4.3L HO, Cobra outdrive
  #8
Old September 29th, 2008, 04:38 PM
I've left many messages, and finally talked to his wife and she said they were not going to fix it anymore. And my lawyer is my sister in law
  #9
Old September 29th, 2008, 05:47 PM
I don't have a cover on the side
  #10
Old September 29th, 2008, 06:01 PM
asdasc's Avatar
That is too bad. I just reconnected my shift linkage over the weekend, because I didn't do it right the first time. I hung over the edge of the boat while it was in the water and it only took about 10 minutes. Without the cover it looks like it is a real job. How do you get at the 3/8 bolt heads? Is the connection farther down the shaft?
__________________
Steve
Livin' the Dream
  #11
Old September 29th, 2008, 11:42 PM
Joe Reeves's Avatar
asdasc ..... On this model, the lower unit must be dropped about a inch or so which then reveals the brass shift connector. The 3/8" hex bolts are removed/installed in the existing gap between the exhaust housing and the lower unit surfaces.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1984 Evinrude 15 HP electric start new_boater Johnson & Evinrude Outboards 2 July 11th, 2007 10:10 PM
Electric start not working on 15-hp Evinrude farginicehole Johnson & Evinrude Outboards 6 October 3rd, 2005 10:56 AM
1974 evinrude 15 Hp Push Button Start Baitcaster Johnson & Evinrude Outboards 2 January 26th, 2005 12:48 PM
Tell Tale Location, 1974 Evinrude 15 hp E/start RDC67 Johnson & Evinrude Outboards 1 July 18th, 2004 08:42 AM
1985 15 hp evinrude installing electric start can it be done cdew43 Johnson & Evinrude Outboards 2 September 22nd, 2003 08:42 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
