Re: Mercury 15hp cooler problem
Not completely familiar with your engine, but from my drawings I see that the telltale comes from the bottom of the exhaust cover. That established, you should be seeing water regardless of it being in gear or not...
The first thing I'd be checking is to see if water is actually getting to the engine... With it running and the covers off, check the temperature of the exhaust cover... you should be able to hold your fingers on the cover easily. If the cover is too hot to leave your fingers there, you have a water supply problem.... Who checked that the impeller was fine? Did they make sure the 2 washers were in place, either side of the impeller? There is also a pipe between the water pick up (under the cav plate) and the water pump base, with a rubber seal on each end.. are they in place and sealing correctly? Are the gaskets either side of the water pump base plate sealing properly?
Just a couple of things for you to start with....
If the exhaust cover is cool to the touch, then just get some compressed air and blow the telltale line out. Easy...
Chris...........
