  #1
Old September 29th, 2008, 07:30 AM
loveeverybody loveeverybody is offline
Default Alarm sounds continuous on johnson 115 "79
Drove wot, alarm sounded, for the first time. Not sure what this means on this motor? Is there anyone out there that has an Heads, Up sure would appreciate it,Thanks! Also this motor ran fine, until I drove it into A sandbar.
Initially I thought sand ,debris; were suck in the lower unit. After this brilliant
moment, I put in reverse only to notice it was less power,not as smooth and
water pouring over the transom. It was a change on how it performed in reverse! In forward gear it ran just fine. I pushed it to wot, heard the alarm
sound, and backed off the throtle , the alarm ceased. All day no alarm sound
even at higher speed. So I thought, maybe if something got sucked in; it had worked itself out. pulling the boat out of the water I noticed what look like Dirty oil or exhaust all over the lower unit just below the cowl. Once again a first with this engine; Maybe to much oil in gas mixture? Anyway got home ran it with muffs
alarm sounded on start up ; this has never happend before. So I took off the cowl and followed the harness from the control box to the red plug wiggled it a little bit started it up no alarm. engine idles fine runs great and strong. Checked the gear oil GOOD! Well I hope with disclosing these symptoms will
enable you guys out there to figure this one out. Thanks Again!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Continuous Engine Alarm Salmosalar Mercury & Mariner Outboards 2 May 11th, 2008 06:49 PM
"NO OIL" light with continuous alarm NgtvNrg Johnson & Evinrude Outboards 2 October 23rd, 2007 06:28 PM
"Sticky pilot" '74 115 'rude; also sounds as if dying in neutral sprite115 Johnson & Evinrude Outboards 4 July 12th, 2007 12:20 PM
Mariner 30hp Continuous Alarm TSoko Mercury & Mariner Outboards 10 October 1st, 2006 11:57 PM
79 Evinrude 115 Overheating alarm Minneaux Johnson & Evinrude Outboards 2 August 22nd, 2005 10:27 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
