  #1
Old September 27th, 2008, 05:38 PM
jmarshall8 jmarshall8 is offline
Default 2000 90hp Mercury 4 stroke not charging battery ??
Can someone help me diagnos my problem???
  #2
Old September 27th, 2008, 05:44 PM
Default Re: 2000 90hp Mercury 4 stroke not charging battery ??
As I continue my search I have found I need to check the rectifer. A few days ago I hooked up my battery backwards. It blew a fuse immidiatley. I changed it and everything seemed fine. I have read this can also damage the rectifier. Where will I find the rectifier and how do I check it?
  #3
Old September 27th, 2008, 05:56 PM
emckelvy emckelvy is offline
The most common cause of charging system failures on an outboard is failure of the rectifier. In your case, you should have a combined rectifier/regulator unit.
As I'm typing this, I see your next post regarding swapping of battery cables. This is 99.9999999 percent guaranteed to 'smoke' the rectifier. The flow of current thru the diode pack is instantaneous and far exceeds the amperage capability of the sensitive electronic parts.
So, my recommendations below still stand, but obviously the cards are stacked against the rectifier being a "Survivor"!
"Check all the electrical connections for corrosion/damage, make sure the ground wire(s) are snug and in good condition.
You can check the resistance of the charging coil wires coming from the stator. I don't have those values in front of me, but typically they'll be very low (in the area of just ohms or tenths of ohms.) If you check the stator wires with a digital VOM and get an open circuit (no continuity i.e. infinite resistance), the stator's shot and must be replaced.
I'd bet more on the rectifier/regulator unit myself. But you really need to check stator before spending $$ on an expensive rectifier/reg. Pick up a cheap VOM from Sears or Rad Shack, it'll be more than adequate for some resistance checks."
I'd plan on replacing, heck you might pull it off the motor and find the back is blown out! But it'd still be a good idea to check the stator resistance, just to make sure the reverse-current didn't damage anything else.
HTH & give us an update when you fix the problem........ed
  #4
Old September 27th, 2008, 06:04 PM
Thanks for the info...now if you can help me find the stator and the rectifier/regulator I can get started...
  #5
Old October 19th, 2008, 11:54 AM
Thumbs up Re: 2000 90hp Mercury 4 stroke not charging battery ??
EMckelvy, thanks for the info. I replaced the rectifier and the problem was solved.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2000 johnson 90HP battery alexedit Johnson & Evinrude Outboards 3 July 8th, 2007 02:04 PM
1999 Yamaha 90HP(2 stroke), not charging battery gst Yamaha & Suzuki Outboards 9 November 1st, 2005 04:41 AM
Fogging a 2000 Merc 90hp 4-stroke jpowers Mercury & Mariner Outboards 1 October 12th, 2005 07:19 PM
Honda 9.9 4 stroke - Battery charging problem coiro Honda & Tohatsu/Nissan Outboards 1 September 12th, 2005 12:19 PM
2000 Johnson 90hp 2 stroke 1sinbad2 Non-Repair Outboard Discussions 1 February 9th, 2004 04:54 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
