  #1
Old September 27th, 2008, 05:06 PM
pattimac pattimac is offline
Default Bayliner Floor-Need help
I'am new to this forum. I have a 91' 21 foot open bow bayliner. I removed the carpet to install new. It's clear that the thin layer of epoxy or Poly layer they put over the plywood floor is cracking and flacking away. In a few places, (about 5 or 6), the top layer of the plywood is gone (approx silver dollar size each). The plywood, even in these places seems rock solid and I can't push a screwdriver into it at all. There is one place below the steering wheel where there was actually a round whole about 2 inches where it looks like they either missed coating the plywood OR they "shot" foam into the hull through it. Anyway, the foam beneath is not damp either.
The areas under the rear seats are clean and dry like the day we bought it and the sprayed covering over all the wood is excellent...except for the main floor as I have described. My question is...since there doesn't seem to be any damage below the top layer of plywood in these few areas, can I simply sand down all the flacking epoxy or Poly on the floor and reglass the main area?
I would put pictures in, but I can't figure out how to do that!
If that seems reasonable, do I use the Poly or epoxy over the glass mesh! I bought it new, so whatever was stock on the floor is still there.
Any comments would be appreciated.
  #2
Old September 27th, 2008, 10:07 PM
gcboat gcboat is offline
Default Re: Bayliner Floor-Need help
If you feel certain that the stringers and transom are in good shape then your plan of attack is OK. You'll need to properly sand and clean the area and then just roll on your choice of product. From the factory it was probably polyester but you could go the epoxy way if you wanted to.
Remember properly prepped and properly cleaned is the key to this project. Neither poly nor epoxy will adhere to dust, dirt or pretty much any contamination.
As far as pic posting is concerned go to the FAQ and look there. You'll find all the help you need.
__________________
Life may not be the party we hoped for, but while we are here we might as well dance
  #3
Old September 28th, 2008, 03:07 AM
DrCox's Avatar
DrCox DrCox is offline
First,
Dont assume everything is good underneath just because the plwood is dry. I just started pulling out my decking on a restore project. Plywood was nice and dry, no wet rot apparent but below lies my real problem, rotten stringers. The problem is not all your water soaks into the bottom from your flat deck. Alot of water finds its way through very small holes or cracks in seams and along the transom. Wood can "wick" up the water and spread it throughout the underneath thus causing rot. So theoretically you could have everything rot out from under your nice fresh plywood.
Sorry, not trying to scare you but I was blown away how rot spread on some things and not others.
Here is my resto link if you are interested:
http://forums.iboats.com/showthread.php?t=275871
Good luck,
-DrCox
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Need your help on Bayliner Arriva before I start repairing the floor (deck). shiftymagoo Boat Restoration and Building 5 October 2nd, 2009 01:00 PM
Need help glassing a Bayliner floor - question carolinadarin Boat Restoration and Building 16 May 31st, 2008 08:11 PM
Need Help With Floor!! HAPPY GILMORE Boat Restoration and Building 4 September 12th, 2007 10:53 AM
84 Bayliner Capri; Replace floor and Redesign cockpit need ideas gotboostedvr6 Boat Restoration and Building 21 May 7th, 2007 08:22 PM
1996 bayliner capri 1700 LS need help with floor!!! cgaviator Boat Restoration and Building 5 April 30th, 2007 12:26 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
