Re: Mercury out borard 2 stroke
1973 85hp cooling problem. Water not coming out of the head until 2000 to 3000 rpm. At idle it stops flowing completely. After changing the impeler and the impeller housing, ( the old one was in good condition) it was no help. We have double checked the impeller installation, shot compressed air all thru the water passages, and still the same result. Head gasket looks good. While running at 2000 to 3000 rpm, the water starts to flow from the top and is very hot.. any suggestions. thanks
