  #1
Old September 26th, 2008, 11:03 AM
ricky_18 ricky_18 is offline
Question 2007 Pricecraft 90hp 4 Stroke Mercury Prop?
what would be the recommended prop for a 17 1/2 Princecraft with a 90HP 4 Stroke Merc on the back? i am new to this and was looking for suggestions
thanks in advance
  #2
Old September 26th, 2008, 11:22 AM
rndn rndn is offline
Default Re: 2007 Pricecraft 90hp 4 Stroke Mercury Prop?
Welcome to the forum!!
If you already have a prop on now it will be much easier for us to help you if you tell us how your current prop is performing. What rpm's do you reach at wide open throttle (WOT)? What is your top speed. What do you usually do with your boat, ie: water sports, high speed runs, etc? Finally, what is it about your current prop that you are trying to fix by buying a new prop?
__________________
1996 Crestliner 2160 Phantom, 1996 Evinrude 130 HP
  #3
Old September 26th, 2008, 11:42 AM
current prop is a 13.25X17P reason for replacing it is cause it got dinged last night. A couple guys suggested going up to maybe a 19P but i know little about it. As for RPM now i run WOT in between the spec of 5000 - 6000 rpm. The boat is primarily used for fishing/trolling but in summer months is used for cruising as well as some tubing. Top speed is 37-38 GPS.
  #4
Old September 26th, 2008, 12:38 PM
steelespike steelespike is offline
What is the actual max rpm?
  #5
Old September 26th, 2008, 12:54 PM
6000
  #6
Old September 26th, 2008, 01:04 PM
TJEli TJEli is offline
With one person in the boat you can actually hit 6000 RPM? Going to a higher pitch prop will increase your trolling speed and hurt your out of the hole performance. If you can hit 6K on the tach at WOT with a light load, sounds like you are propped correctly now for what you use the boat for.
-Eli
  #7
Old September 26th, 2008, 01:14 PM
Irv964's Avatar
Irv964 Irv964 is offline
Quote:
thanks in advance
Here is a good thread for you to read, my boat is similar to yours, just 1 foot shorter.
lots of good info on gear ratios, motor height, max rpm etc. Be sure to read the links within the mulitple posts. Good Luck.........Irv
http://forums.iboats.com/showthread.php?t=269778
__________________
2006 Lowe165 F&S
2007 90 Merc 4 stroke
19P Turning Point Hustler Prop
  #8
Old September 26th, 2008, 01:36 PM
thanks for the link
i can turn over 6000 rpm with 2 or 3 people but was not sure if i should as its above the WOT limit....
  #9
Old September 26th, 2008, 05:22 PM
thanks for the link
Thats the info we needed.You need to go up in pitch shoot for 6,000 with one or two aboard.Or be very aware of your rpm.Higher pitch should give more top speed and maybe a little mileage edge probably not too noticeable.
(more speed with less throttle)You might consider the Hustler turning point prop.It is said to deliver stainless performance at aluminum prices.
You could probably get your prop repaired for a spare.
  #10
Old September 26th, 2008, 09:27 PM
ok guys you have been so much help!!
here is the info from tonights test's
two people in the boat both weighing about 150lbs each and a quarter tank of gas. The gas tank holds 132 L (35 U.S. gal.)
13.25X 17Pitch
Max Speed: 40mph
RPM: Rev Limiter Beeps around 6100-6200 rpm
13X19 Pitch
Max Speed: 43mph
RPM: 5700-5800 rpm
any suggestions now?
thanks in advance
  #11
Old September 27th, 2008, 09:53 AM
I would say your ok with you alone you would be about 5,900 your not likely to get much closer than that.If you haven't fine tuned your setup you could try raising the motor a little at a time.If you have no venting problems your
probably too low.
  #12
Old September 27th, 2008, 10:41 AM
Runaway_Alumacraft Runaway_Alumacraft is offline
Instead of the Hustler, use Turning Point's "Legacy" series. Same prop as the Hustler, but has the Merc hub technology!
__________________
09 Ranger 619, full windshields powered by a 225HO ETEC, loaded with all the goodies.
01 Alumacraft Tournament Pro 170 Elite Re-powered with an 08 115 Evinrude ETEC ...WOW! SOLD
  #13
Old September 27th, 2008, 11:43 AM
probably too low.
what exactly do you mean by that?
  #14
Old September 28th, 2008, 08:28 AM
Irv964's Avatar
What he means is, if your prop holds well in tight turns after you have trimmed up and you still get no ventilation(prop blow out) then your motor could quite possibly be too low?
Your cavitation plate should be at least level with the bottom of your boat when you are fully trimmed in(down) That is usually a good starting point. Raise your motor 1 hole at a time until you find your optimum setting. Good Luck..........Irv964
__________________
2006 Lowe165 F&S
  #15
Old October 19th, 2008, 08:36 PM
finally got the time to get a Turning Point Legacy Prop and went out with the girlfriend to test it... 3/4 tank of fuel and 2 of us in the boat (approx 300lbs) here are the results
13 1/4 X 19 Pitch
Max Speed: 43mph
RPM: 6000 rpm
could i go more or is that my max?
  #16
Old October 19th, 2008, 10:22 PM
Irv964's Avatar
13 1/4 X 19 Pitch
Max Speed: 43mph
RPM: 6000 rpm
I think that is pretty good myself, I assume my boat weighs a little less than yours and my test results were, with just over a 1/2 a tank (14-16 gals?) and by myself(190lbs) 44mph as per GPS so I think your doing great.
Your at your max rpm for that motor so imo that is it? If your looking for more speed you could try a 21 but I think your motor will only push about 5600 rpms so I am not sure if you would see any speed increase?
I was after a better holeshot and less blowout in the turns and that is what I got, the 2mph increase and my motor being able to reach it's max rpm were just bonuses to me! I am completely happy with my set-up now.......Irv964
__________________
2006 Lowe165 F&S
  #17
Old October 19th, 2008, 11:18 PM
thanks Irv
this is my boats specs:
Princecraft Pro 174 SS
Approx. Weight: 585 kg (1289 lb.)
Gas Tank Built-in: 132 L (35 U.S. gal.)
I don't need the top end but was curious if a 21P would get me more top end.
i also have a 19P Black Max i would be interested in trading someone for a 17P as i wish to use it for trolling.
  #18
Old October 20th, 2008, 01:16 PM
Irv964's Avatar
thanks Irv
I think you got great results with your Turning Point prop, better than mine and I am completely happy too. I personally don't think running a 21 on yours will net you any more top speed but then again this prop stuff sometimes screws up all logic?
I am still a little curious on that Stiletto SS I was thinking of purchasing, would I see more speed, same RPM, better holeshot, even less cavitation? For the money, I will stick with my Turning Point just in case the Stiletto is no different or not as good but in your case and the cheap prices of Turning Point props, it may be worth a try?
My BlackMax is also a 19P, if it were a 17P I would give it to you, I hated it that much!
What dealer do you deal with in Bellville? I deal with Upper Canada Marine in Havelock and so far so good, they have treated me well........Irv964
__________________
2006 Lowe165 F&S
  #19
Old October 20th, 2008, 01:25 PM
thanks Irv again! its been a treat. I still may see if i can borrow a 21P just to get rid of my curiosity. I now sit with 2 19P props the black max as my spare.
as for who i deal with, i deal with Big Lake Boats in Cobourg, they have always been great with me. I would recommend them to anyone.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2007 Mercury 115hp 4 stroke - Smartcraft? dbski4it Mercury & Mariner Outboards 9 July 22nd, 2008 03:13 PM
Mercury 2007 90HP 4-Stroke EFI Fuel Problem tj266106 Mercury & Mariner Outboards 0 July 5th, 2008 07:37 PM
2007 50 hp 2 stroke Mercury prop jauguston Prop Questions and Topics 4 May 2nd, 2008 10:07 PM
Prop Pitch - 2007 Mercury 9.9 GregE Prop Questions and Topics 6 April 30th, 2008 02:41 PM
2007 9.9 Mercury 4 stroke propper_advice Mercury & Mariner Outboards 2 October 9th, 2007 08:36 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
