I just bought a 1999 ProCraft with a Mariner 150. From a cold start, the outboard starts very easily and idles very smoothly right around 1000 RPMs. Once I idle out past the no wake zone, I start to give it a little throttle and as soon as it gets to about 2000 RPMs the Low Oil/High Heat indicator light comes on. I take it back to an idle and back to neutral and the light goes off. I have checked and the oil levels are fine, the oil tank caps are on tight (I was told to check that this could cause vacuum issues). The low oil/high heat indicator is one and the same on the dash panel so I dont know which issue I am running into. Any thoughts on what I should check?
Thanks,
Thanks,
