fluidjuice
- Jun 12, 2008
- 54
Engine started hard today in water, but fine on muffs.
ran great for about 1 hour ,dropped rpms to idle into harbour and engine stalled, took of cover and found fuel dripping from bottom carb from the throttle shaft the bit with the small spring on. tied up kept cranking with no luck managed to start it about 20 minutes later, any ideas why its leaking here and would this be the reason for the stall when idled.
Mercury 40hp classic 1991 twin carb 4 cylinders
