  #1
Old September 24th, 2008, 10:28 PM
ronrobbie7 ronrobbie7 is offline
Default 4.5 hp Mercury carb problems
Does anyone know the correct settings for the carburator my 1976 Mercury 4.5 hp outboard or where I can find this information. I took it apart to clean it and now I want to make sure the screws are set right. Thanks, Ron
  #2
Old September 25th, 2008, 02:02 AM
emckelvy emckelvy is offline
Default Re: 4.5 hp Mercury carb problems
Ron, about the only screw I can think of to adjust on the carb itself would be the idle mixture screw. The main jet is fixed so you can't do anything with that.
To get a very rough setting on your idle mix, lightly seat the needle (fully clockwise) then back out approx 1-5/8 turns. This should be close enough to get 'er started.
These Little Ones don't flow a lot of air or fuel so they're quite touchy on the mixture adjustment, make small changes on the mixture needle and let things settle out for 15-20 seconds before 'tweaking' on it more.
Adjust for smoothest/fastest idle, if it gets cranky on the re-start or is overly cranky when cold, richen the mixture (CCW) 1/16-1/8 turn.
Note: if you need to adjust the idle speed, use the Throttle Stop screw. It's the one with a locknut upon which the throttle linkage rests at Dead Idle.
Don't mess with the Spark Advance/Stop screw, which is the one that limits the travel of the linkage at Full Throttle.
HTH..........ed
  #3
Old September 25th, 2008, 05:16 PM
Thanks for the help, I appreciate all the help I get from the great people here!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury carb problems donnie2 Mercury & Mariner Outboards 1 September 8th, 2007 02:55 PM
40 HP Mariner Carb Problems banchigu Mercury & Mariner Outboards 6 January 10th, 2006 04:41 PM
Mercury 8horse, ??year, carb problems NWRedside Mercury & Mariner Outboards 4 August 27th, 2003 03:05 PM
1996 mercury force 75 ELPT- Carb problems ckirby Mercury & Mariner Outboards 1 April 15th, 2003 08:57 PM
1996 Mercury 9.9 Carb. Problems abcheek Mercury & Mariner Outboards 2 January 7th, 2002 06:13 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
