blackspot3
- Jul 26, 2008
- 3
I have a 2001 Merc 5.7 EFI I/O that has the following symptoms.
After starting and running fine, it will occasionally crank without starting. Cold, hot, after long idle doesn't seem to matter. If I push forward to full throttle, it will start with a lot of fuel smoke (black, not blue). I have been told the EFIs have a sensor that may be going bad. Is this something I can replace myself or is it best to take it in and have a tech run diags on it?
Thanks in advance!
Thanks in advance!
