  #1
Old September 23rd, 2008, 06:09 PM
Gunther Gunther is offline
Question Mercury Tach correct
I am looking to buy a 2004 17 foot Lund Explorer with a 115 Optimax on it. We took it for a test drive the other day and at idle it is 1000 RPM. Listening to it seemed a little high but not really. At about 50 percent throttle we reached 6000 RPM and about 25MPH. We still had plenty of throttle left and at top end tach was pegged and we were doing about 40MPH. The motor does not sound like it has excessive RPM at top end. Guessing from the tach reading at 50 percent throttle if you trusted the tach there would have been about 9000 RPM at top end. Max for a optimax should be 5750 RPM. If the switch setting is incorrect on the tach I am guessing it would be proportionally off. I am on the right path or not? Any suggestions would be appreciated. I did check the prop and it appears to be the factory prop and does have a ding or two on it but nothing major.
Thanks
  #2
Old September 23rd, 2008, 08:35 PM
hkeiner's Avatar
hkeiner hkeiner is offline
Ensign
Default Re: Mercury Tach correct
Yes, it is likely that the switch setting on the back of the gauge is incorrectly set. The below thumbnail contains the specs for setting the switch.
__________________
1996 Mercury 150HP V6 carbed outboard motor and Maxum 1900XR bowrider boat
  #3
Old September 23rd, 2008, 11:20 PM
Thanks Chief. Getting the boat on Friday and hopefully will be able to fix it quickly.
r/
ETCS
  #4
Old September 29th, 2008, 01:09 AM
O.K. I got the boat and started doing some basic testing. When I turn the key to the on position the tach does change, however it only goes down to 600 RPM without starting the engine. I attempted adjusting the cal screw but the lowest I ever got it to was 600 RPM. I believe the Tach is shot and should get a new one. Any comments.
Thanks
  #5
Old September 29th, 2008, 01:40 AM
hkeiner's Avatar
Ensign
The gauge should go to zero when the key is turned on and the motor is not running. Since it does not, the gauge is probably bad. You might also retry this test while disonnecting the SEND wire from the back of the gauge. If the gauge then goes to ZERO with the wire disconnected, the gauge may be good and the send wire from the motor is causing a problem.
Check out the below link for more information on troubleshooting tachs.
http://www.downloadingfiles.co.uk/te...es/page342.pdf
__________________
  #6
Old October 6th, 2008, 10:41 PM
Thanks for the guide, I hopefully will have time to check it out this weekend.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Correct prop? or bad tach? thewooddogg Prop Questions and Topics 4 August 8th, 2007 05:14 PM
correct tach setting please?? GlasV162 Johnson & Evinrude Outboards 3 June 26th, 2007 11:57 PM
Correct tach for 115hp Johnson tbeaun Johnson & Evinrude Outboards 7 July 23rd, 2005 05:57 PM
Correct tach for 115hp Johnson tbeaun Non-Repair Outboard Discussions 1 July 21st, 2005 01:18 PM
Correct tach for 115hp Johnson tbeaun Johnson & Evinrude Outboards 2 July 21st, 2005 11:12 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
