  #1
Old September 22nd, 2008, 04:16 PM
trent 1 trent 1 is offline
Default 1977 mercury 115 outboard cooling system
I have a mercury 115 that after starting, water flows for a good little bit, thens stops. I have put in a new impeller kit and housing. You can idle for about 4min then stops and keep running in about 30seconds it starts again real slow. If I try to idle up it stops in about 1 min from take off.
Is there a switch or thermostat that does this, I do not hear any alarms, and water seams to be warm to touch when it is flowing. I can't tell if someone else has bypassed something or is there some thing I need to by pass.
Please help.
  #2
Old September 22nd, 2008, 04:48 PM
Chris1956 Chris1956 is offline
Default Re: 1977 mercury 115 outboard cooling system
Trent, That motor does not have any thermostat or valves that would do slow or restrict water flow. The telltales do clog easily and you can clean them up with a piece of wire.
On the flusher, water should come out the gratings above the antiventilation plate, as well as from the prop hub. Some water may come out the square holes higher up on the midsection. The exhaust cover (flat plate on port side of motor) should be cold when running on flusher at idle. If it is warm at idle you have a cooling problem.
  #3
Old February 5th, 2009, 11:04 PM
camanorich camanorich is offline
Chris
I don't understand why some engines don't have a thermostat? I thought that the reason for one was so the block temperature wasn't quite so drastically different than the combustion chamber. I've read forum threads where people asked about just not putting in thermostats, and the answers were that by having the block be too cool, the engine would be ruined in no time do to the block not getting warm enough. I've got an 115 HP merc (approx 1973) and my friend that's working on it told me that the block seems so cool that he could probably put his face against it! Anyway, if you or someone else can explain to me how these engines perform and not wear out with this set-up. I would be grateful.
Thanks
Richard (Camano Island, WA)
  #4
Old February 5th, 2009, 11:28 PM
Plainsman's Avatar
Plainsman Plainsman is offline
Is this a newer to you engine? There could be something in the watertube so that when you accelerate it's forcing more water into the tube and pushing the object up and restricting it, maybe a piece of the impeller.
Just my .02
__________________
Rest in Peace Spinner
1978 SSV-176 Glastron with a 1976 115 hp model 1150 , 1972 Mercury115 hp
Your friend,your partner, your defender,your dog.You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion....by E.F. Henry
I am NOT a mechanic, but I did stay at a Holiday Inn Express
  #5
Old February 6th, 2009, 01:36 PM
Rich, Merc designed a lot of their motors in the seventies and eighties without thermostats. These motors ran very cool at idle and warmer at speed. As long as you had the correct prop for the boat and load, and a good waterpump impeller, they worked pretty well. They were carborated to work under these temperature differences.
Johnny/rude had thermostats on their outboards in the fifties, or earlier. They thought it necessary, and probably had better running motors in cold conditions.
The bottom line is if you have a thermostat, make sure it works properly. If not, make sure you keep an eye on the water flow (water pressure gauge is a good way) to keep the motor from overheating.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1992 Mercury 40 hp 4cylinder outboard cooling system Anthony Mattera Mercury & Mariner Outboards 3 December 27th, 2006 04:24 PM
Outboard Cooling system Snookster Boat Topics and Questions (not engine topics) 1 November 25th, 2004 07:16 PM
Outboard Cooling system Snookster Yamaha & Suzuki Outboards 1 November 25th, 2004 07:16 PM
cooling system on my outboard help;;;;; liverpool96 Johnson & Evinrude Outboards 2 August 12th, 2004 01:44 PM
7.5 Mercury outboard cooling system davidptp Mercury & Mariner Outboards 1 July 1st, 2002 04:10 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
