Hi,I am new to boating and that is why i have this problem.I have bought a boat with a 77 marine 2 stroke outboard 40 hp. motor that had a problem to start with.While the motor was running the starter would kick in due to the start switch sticking.So i decided to replace it,bought a key switch from local marina and started working.I identified the battery wires,the electric choke and the solenoid and tested each as i progressed.I could not figure it out the magneto and the ignition wires,i thought i had it but when i tried to start the motor it turned a few times and went dead.I found out that i blew up a 20A fuze on the wire leading to the solenoid,replace it changed the wrong wires to the correct position and tried to start it but still nothing.The new fuze is good but i i probably burned something else too.I have no ideea at this point so if someone thinks that can help me i would greatly appreciate.
