Duke of ....
- Aug 9, 2008
- 15
Have a 2.5 I/O Mercuriser..
When the engine stops on its own after running just for a shot period of time I can see fuel still going into the Carb.
Even if I turn the engine off, still see fuel going inside Carb. (stops on it's own after about 1 or 2 oz. of fuel)
Engine will not start again unless I wait about 20 or 30 minutes, then it starts and runs rough and when it stops,,,,,,,,,, same problem as above.
Don't have a service manuel and not sure which of the two screws on the Carb. is air mix and which is fuel mix.
Outter plate on Carb. is set to the lean side also if that's any help.
Thanks for any help,
Duke of ....
Duke of ....
