Hi all i just bought a 79 johnson 35 it has been sitting up 4 years the previous owner said. the motor looks pretty clean the wiring harness is toast and of course the carb had syrup in the float bowl. but the major problem is the shift lever will only move about a half inch into forward and wont move at all into reverse. any ideas i am going to pull the lower unit to change the water pump but want to see what you guys think
