99 60hp mercury tracker bogging down
saltynut
Hello all , I have a 99 mercury outboard that sat idle for 7 years, removed all three carbs cleaned them good , replaced all three spark plugs , will start fine and idle but after idling for a period of time or trying to put a load on it will bog down and die will restart fine and if you put in neutral will rev good but bogs under load again any help would be greatly appreciated and also is there a setting for the feul mixture screws or should they be adjusted till they run right,,,thankkx again for any help you can provide. Rob
CharlieB
Re: 99 60hp mercury tracker bogging down
Pump the primer bulb, any difference?
The check valves in the fuel pump may be leaking.
saltynut
Thanks Charlie I replaced the primer bulb and took apart the feul pump cleaned and inspected it , took the boat out last night idle only lake but it ran better than it has been so will wait to see on a lake where I can open it up.
