  #1
Old September 20th, 2008, 09:10 AM
sima sima is offline
Default prop selection for the slightly used boat
Hello everybody.
I just got a 2004 185LX Stingray and need to change the prop.
I have 3.oGL-CVolvo Penta engine. It uses SX / Cobra Drive (Single Propeller).
135 HP, WOT range 4200-4600.
I think I would like to get an Aluminum 17" pitch prop. Being in Minnesota, I will be using this boat on the lakes or rivers mostly for family recreation.
It looks like my options are:
Michigan Match Aluminum Propeller
Black Diamond with Flow Torq Hub Aluminum Propeller
QL Aluminum Propeller
The difference in price is about $30 between the Michigan and the rest.
Being a new to this will I see a difference between the cheaper prop?
Thank you in advance.
  #2
Old September 20th, 2008, 09:55 AM
xxxflhrci xxxflhrci is offline
Default Re: prop selection for the slightly used boat
IMO, you should do yourself a favor and spend the bucks for a stainless prop. They are nearly indestructible. When I was running aluminum props, I was sending one out to the prop shop at least twice a summer from hitting things like small sticks and such. For the past 10 years, I have been using stainless. My prop still looks like new.
Anyway, I have a 17.5 ft boat with a 3.0. I get 40 mph or so at 4600 rpm out of a 3 blade 19P.
  #3
Old September 20th, 2008, 04:45 PM
freddyray21 freddyray21 is offline
I would not run a stainless prop in the river around here. An aluminum prop will give if you hit something a stainless prop will not. When the prop does not give something else has to. Usually the gears in the lower unit. Stainless is great for lakes where you know your depth, but not the rivers around here imo.
  #4
Old September 21st, 2008, 09:16 AM
Thank you all for the advice.
One more question.
What is the difference between this 3 brands:
Being a new boater will I see any difference if I get the cheaper one (Michigan) vs others?
thank you.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
should prop move in and out slightly snake91876 Prop Questions and Topics 6 April 24th, 2008 02:09 AM
Prop Shaft Slightly Bent xcleox Mercury & Mariner Outboards 1 April 22nd, 2008 01:23 AM
Prop selection on an outboard powered work boat la350 Prop Questions and Topics 3 September 22nd, 2006 10:19 AM
Boat Prop Selection Help ILIKEROSTERTAILS Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 18 August 14th, 2004 02:02 PM
very, very, slightly bent prop shaft heaty1 Non-Repair Outboard Discussions 2 April 16th, 2001 08:20 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
