  #1
Old September 20th, 2008, 08:49 AM
gnarbrah's Avatar
gnarbrah gnarbrah is offline
Default 1989 Evinrude 9.9 Impeller
OK - Here I am again. I seem to be changing motors like the weather but I think I've got a winner this time. I picked up a 1989 Evinrude 9.9 for $300. It starts right up and runs great but the telltale just has a steady drip never a stream. I'm REALLY hoping it just needs an impeller and as soon as the store opens I'm going to get one and change it out. I'm ready to get on the water today!
Just want to see if it's a similar setup to access it as my 1975 6hp and the 1970 9.5 I just did impellers on. Drop the foot, disconnect the linkage and there it is???
Thanks!!
  #2
Old September 20th, 2008, 08:58 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 1989 Evinrude 9.9 Impeller
you can see diagram here. http://shop2.evinrude.com/ext/index....cfd8a6471c0f7f
shift may disconnect under the carb.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old September 20th, 2008, 10:17 AM
gnarbrah's Avatar
Good news! I removed the 6 bolts holding the foot on moved the shifter into forward and it dropped almost an inch exposing the coupler plain as day! I'm about to open the impeller housing and take a look but should I squirt the garden hose up the tube to try and flush the system out and make sure there's good flow out the telltale?
  #4
Old September 20th, 2008, 01:12 PM
gnarbrah's Avatar
Alright I found an impeller and got everything back together ok. Now my question is what kind of pressure should I have coming out of the telltale? It's is markedly improved and has a stream versus the steady drip before but it's not a super stream and a breeze can break it up (if that makes sense). I can't really throttle it up because this model will only let you throttle up a little in neutral. It has to be in gear to hit the gas and it blows all the water out of my barrel. I guess I'm going to put her in the lake and see what happens. The reason I ask how strong the stream should be is I've seen some boats (granted they were probably 200hp motors) that shoot a stream that would almost hurt your hand if you got it under there. For the record I blew compressed air up the telltale and a little garbage came out but nothing major. Then there was a steady stream of air behind it.
Thanks
  #5
Old September 20th, 2008, 06:06 PM
LORDY611's Avatar
LORDY611 LORDY611 is offline
I think the force that the telltale has might be different with various motors. The stream is only an idicator that the impeller is moving water. In no case should it imitate a pressure washer, but a drip is probably a bit on the low side. If you cleaned gunk out of the tube and changed the impeller, chances are that you have fixed the problem and should be good to go.
  #6
Old September 20th, 2008, 06:13 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
That telltale outlet has a habit of clogging somwhat. With the engine running, clean that fitting out with a piece of single strand steel wire. Youmay need to remove the hose from the fitting to clean it thoroughly BUT the steel wire route usually does the job.
  #7
Old September 21st, 2008, 10:27 AM
gnarbrah's Avatar
Well I took it out on the lake and it ran great power wise and then I noticed that it basically quit pumping out the telltale....not too happy. It would have a weak stream only when I was running at WOT. Once I slowed down to idle it was a drip if that. I'll look at the telltale and see if it clogged somewhat again. Would the thermostat cause any of this issue? It appears to have never been replaced. Any other thoughts??
Thanks
  #8
Old September 21st, 2008, 11:59 AM
gnarbrah's Avatar
Joe - You are the man! I thought for sure it would be some trash in the water jacket and next thing I knew I'd have the whole power head torn apart but the wire worked! Easiest fix ever!!! It's peeing like a champ!!
Thanks!!!!
  #9
Old September 21st, 2008, 01:26 PM
Joe Reeves's Avatar
Glad to hear you fixed it. Now, just where do I send this bill? (grin)
  #10
Old October 9th, 2008, 09:03 PM
Napa Ed Napa Ed is offline
To clear the telltale carry a turkey baster. The pressure is not that great at the head drain outlet so the smallest bit of scale or algae can clog the peehole. A wire only reaches so far but a turkey baster filled with no air can really jack the drain line and loosen up any minor problem. Somedays I have to backflush a couple of time while on the water so don't be suprised to see a stream turn into a trickle. A long vinyl tube and a mouthfull of water does the same. (engine not running of course)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1989-85hp impeller direction gjm Force & Chrysler Outboards 5 August 26th, 2007 02:31 AM
1989 Mariner Impeller kevinkuper Mercury & Mariner Outboards 2 July 12th, 2005 07:15 AM
1989 chrysler impeller replacement fish4food Force & Chrysler Outboards 7 May 31st, 2004 01:10 PM
replace 1989 Alpha 1 impeller jimmyg473 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 October 6th, 2003 03:20 AM
1989 force 125 impeller location my55 Force & Chrysler Outboards 1 July 13th, 2001 11:49 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
