  #1
Old September 18th, 2008, 07:20 PM
JimmyKoKo JimmyKoKo is offline
Default Help!! Cost To Repair 1981 Mercury 115 Outboard?
I have had my 115 mercury outboard in the shop since early July. I took it in because it would not accelerate properly. Shop diagnosed an issue with water spitting into the exhaust through a leaky gasket. They pulled the exhaust gaskets and replaced. Installed new gasket on the outer housing and replaced the water jacket gasket also. They removed the lower unit and replaced the water pump impeller than lake tested the boat. The lower unit gear case failed during the lake test. Clutch dog came apart and blew a hole in the side of the casing. I found a used lower unit and they again changed the water pump impeller and installed the lower unit than lake tested. Total price $1,134.40.
Is that reasonable?
Thanks, Jim
  #2
Old September 18th, 2008, 07:33 PM
emckelvy emckelvy is offline
Default Re: Help!! Cost To Repair 1981 Mercury 115 Outboard?
Seems a bit spendy since there weren't a lot of parts involved.
How many hours labor did they charge and what was their hourly rate?
  #3
Old September 18th, 2008, 10:40 PM
Thanks for your reply. 11.5 hours charged at $85 per hour
  #4
Old September 20th, 2008, 12:13 AM
Any other thoughts?
  #5
Old September 21st, 2008, 12:54 AM
Almost $1000 labor seems a bit high for that job but it would depend on whether it was a fresh water motor where the bolts all came out nice and easy, or a salt motor where you had to fight every one of them to get the dang thing apart.
Working on Salt Motors can rack up a lot of labor. You have to be real careful or else you'll break bolts. Then it takes even longer to drill 'em all out and install Heli-Coils!
Also, whether they pulled the powerhead to replace the gaskets or just worked them in place.
The lower unit jobs of course would have labor X2, for the original work and then for replacement of the bad lower unit. Since the impeller was brand new from the first time with essentially Zero hours on it, they should have been able to use that in the replacement lower unit. If they charged you for another new impeller, I'd ask why and also ask to see the first new impeller.
BTW, don't think I've ever seen a Merc lower unit self-destruct as you've described. Were you there when they were running the boat? Did they show you the lower unit after it blew up? Seems pretty strange they take the boat out and the lower unit blows up. But stranger things have happened I reckon. Can you say, wind the motor up to Terminal Velocity and slam in gear??
Well, hopefully they did a good job and it's running well. It's irritating to have slow and expensive service, couple that with poor workmanship and it's a real Buzz Kill!!!
Cheers.......ed
  #6
Old September 23rd, 2008, 08:59 PM
Thanks for the information Ed.
I have been skeptical about the explaination for the blown lower unit. I was out of town and they called me after they lake tested it. Said they were about 50 yards away from the dock when the lower unit blew up. Sprayed the boat with oil and then had to be towed back to the ramp. When I got back to town I looked at the lower unit. It was on a rack and had no water in the case below the hole. It was full to the hole with gear lube. When I questioned why, I was told the gear lube must have drained down. That did not make sense to me. If the boat was towed it was in the water for a while and the gear lube should have floated out? It does not add up?
  #7
Old September 24th, 2008, 07:53 PM
Ttt
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 115 outboard help needed...NooB unclenick Mercury & Mariner Outboards 7 August 9th, 2008 01:25 PM
1981 115 Mercury Outboard JimmyKoKo Mercury & Mariner Outboards 1 July 11th, 2008 04:20 PM
1981 Mercury 115 inline skhourey Mercury & Mariner Outboards 12 August 4th, 2007 04:30 PM
Help with a Mercury 115 outboard tricountybass Mercury & Mariner Outboards 1 June 6th, 2007 09:15 AM
1981 Bonicraft w/115 HP Chrysler outboard jblair Boat Topics and Questions (not engine topics) 0 April 6th, 2003 05:28 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
