  #1
Old September 18th, 2008, 02:58 PM
chrisg chrisg is offline
Default Got my toon back with new motor, only getting 15MPH! will changing prop get more spee
I had downsized from a ’87 I6 115 Merc. To a ’99 60 bigfoot.
The Bigfoot has a WOT range of 5000-5500.
The marina put a used 14/13 Aluminum prop on it. My old merc had a 14/15” SS prop.
This is on a ’87 parti-barge, 24-foot pontoon, just me and 10gal of fuel. And only having the gauges on the dash to go by.
At WOT, the RPM was 5800 when trimmed out. The max speed appeared to say 15MPH. I don’t think the motor liked that, it was screaming. It appeared to be happy around 4000 RPM, which moved it at 10MPH.
I’m going to this weekend put my original prop on to see what happens. That would be a 2” increase, and if I recall that would result in a 2*200RPM decrease, or 400, resulting in 5400 RPM, within the range.
What should I get for speed with this motor? Should I get a 14/16 prop, that would put the WOT RPM down to 5200RPM. Would that get my speed up?
Are there special props for pontoons?
__________________
Chris
Gave up on searching for a lake in Iowa!
  #2
Old September 18th, 2008, 03:06 PM
rrhodes's Avatar
rrhodes rrhodes is offline
Default Re: Got my toon back with new motor, only getting 15MPH! will changing prop get more
24' toon with a 60hp would max out around 14 - 18mph deoending on load IMO
You need to change your prop out and your math is right. I would not expect more speed out of it though.
  #3
Old September 18th, 2008, 03:38 PM
Silvertip Silvertip is offline
Something is dreadfully wrong with your numbers. Either the tach is not correct, speed is way off, the prop is not a 13P or the hub is slipping. A BigFoot lower unit has 2.33:1 gears. At 5800 RPM and a 13P prop, the speed on a PLANING hull would be 26 MPH at 15% slip. On a pontoon speed will be considerably less than that but it should be more than 15 MPH. Speed needs to be checked with a GPS and I would have a look at the tach calibration. As far as screaming goes, the 60 BigFoot (assuming its a 2-stroke) is a three cylinder engine whereas the 115 was a four cylinder so it would have different sound. SLowing the engine rpm down does not increase speed. It merely means the engine RPM is less at the same speed you were going when it was running 5800 RPM. If you step up in pitch and the engine is STILL able to turn 5800 RPM, then yes, speed will increase. The idea is to prop the engine so it runs at or near is recommended WOT rpm. Speed will be whatever that combination provides.
  #4
Old September 18th, 2008, 05:18 PM
yes, I would not be surprised if the speedo is off ( That's why I said look like). The mechanic said the tachometer is correct. I'm not too concerned about the speed ( seems fast enough for me - I'll use my other boat for tubing). Guess my concern is should I change the prop to bring the RPMs down? Sounds like I should, but don't expect more speed.
Other then the RPM issue, I'm a happy camper. The motor is a lot quieter, you can carry on a conversation at the back of the pontoon without yelling. And it started with little effort.
Once thing is, you can't see the oil level through the window on the front of the motor, I fill the tank, and almost overflowed it ( The Marina had already filled it). I noticed that there is a warning buzzer under the helm, I hope to get the low oil warning signal working, as running out of oil is the last thing I want to do.
Untill I get the low oil warning system working, I will keep topping up the oil tank.
Should I expect to add oil at the same rate as if mixing in a tank? (IE. When I go through 6 gal of gas, put in the same amount of oil as if I mixed it in the tank?)
Unfortunately, I will be pulling the boat out next weekend and putting it away for the winter.
__________________
Chris
  #5
Old September 19th, 2008, 04:23 AM
SunTrackerPB21 SunTrackerPB21 is offline
"I had downsized from a ’87 I6 115 Merc. To a ’99 60 bigfoot.
The Bigfoot has a WOT range of 5000-5500."
I have a 2005 Merc 60 Bigfoot on my 21' PartyBarge.
I don't know the details on the prop but WOT is 5000 with just 2 of us onboard. When I load it up with 6 or more people, the WOT seems to drop to 4800. It never "screams" but it does eventually get up and go pretty good. No Speedo so I;ll have to take the GPS out nextime for MPH
  #6
Old September 19th, 2008, 09:46 AM
I found out they are charging me 160 for a used prop!!
I told them to give my my old prop back, and they argued that I will reck the motor. I can buy a new prop for less!
SunTrackerPB21: sounds like you should reduce your pitch to up the RPMs. I read somewere that overloading the motor will shorten it life expectancy ( Or is that only for 2-strokes!?) It will also get up and go faster.
__________________
Chris
  #7
Old September 20th, 2008, 04:39 PM
SunTrackerPB21: I just put my old SS prop on, and now the WOT RPM with just me is 4800, so I'll have to see if this is really a big deal or not.
I asked the question in the prop forum.
__________________
Chris
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
found the motor I want for my toon chrisg Pontoons 10 August 26th, 2008 05:12 PM
Changing out back-back seats dalew555 Boat Topics and Questions (not engine topics) 3 July 8th, 2008 01:28 PM
new to me toon owner nscrnt8 Boat Topics and Questions (not engine topics) 3 April 8th, 2006 01:59 PM
new toon prop/rpm question MichaelMullis Non-Repair Outboard Discussions 3 May 4th, 2005 05:36 AM
Dhadley, OB and others: Prop Question for toon rickdb1boat Non-Repair Outboard Discussions 24 November 13th, 2003 03:49 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
